Platformio does not accept upload port
I’m about to go absolutely insane with this problem. I just can not get platformio to accept any port.
I’m running Fedora 34.
Here is my config
[env:ATmega1284P]
board = ATmega1284P
upload_port = usb
upload_protocol = atmelice_isp
upload_flags = -e
When I run avrdude through terminal it will happily accept usb or nothing at all as an upload port, when running set fuses it will also find my board without any trouble. But putting usb (as in my config) it will spit out
No such file or directory: ‘usb’
through pio device list I can see my programmer is connected to /dev/ttyS0 but using that will give me
avrdude: jtag3_open_common(): JTAGICE3/EDBG port names must start with "usb"
Using /dev/ttyS0 in terminal will give the same error. I’ve been trying to get platformio to ignore the upload_port and send it through to avrdude anyways since it seems it can handle it but very unsuccessfully.
avrdude command I used to check connection
avrdude -p ATmega1284P -c atmelice_isp
Any guidance is very appreciated.
Have you tried per docs
[env:ATmega1284P]
board = ATmega1284P
upload_protocol = custom
upload_port = usb
upload_flags =
    -C
    -p
    $BOARD_MCU
    -P
    $UPLOAD_PORT
    -c
    atmelice_isp
Youŕe a legend!
I was fiddling around with that config earlier in great anger and somehow screwed it up. It appears to work now. Big thanks!
