But I can’t upload the firmware; I get the following errors. Surely, I’m making a major mistake. Who can help me?
Checking size .pio\build\genericSTM32F103C8\firmware.elf
RAM: [== ] 21.1% (used 4312 bytes from 20480 bytes)
Flash: [=== ] 29.8% (used 19520 bytes from 65536 bytes)
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, serial, stlink
CURRENT: upload_protocol = dfu
Looking for upload port...
Auto-detected: COM14
Uploading .pio\build\genericSTM32F103C8\firmware.bin
maple_loader v0.1
Resetting to bootloader via DTR pulse
Searching for DFU device [1EAF:0003]...
dfu-util - (C) 2007-2008 by OpenMoko Inc.
This program is Free Software and has ABSOLUTELY NO WARRANTY
Couldn't find the DFU device: [1EAF:0003]
-Dfu has never worked for me
-doesn’t it select the com port by itself?, then from the log I see that it selected the right port by itself…
-maple bootloader doesn’t load it by simply inserting this line?
board_build.core = maple
you set PlatformIO up to expect a board that already has the Maple (DFU) bootloader flashed onto it.
Initially, you have to burn the Maple bootloader into your STM32F103C8 by using the UART bootloader (serial) or SWD (e.g., with ST-Link) uplink method and a software like STM32CubeProgrammer.
Once the Maple bootloader is burned into the device, then it will appear as a USB DFU device with VID:PID 1EAF:0003 to the computer, and the uploader program can upload via USB.
This will not work at all if you don’t yet have the bootloader burned into your device beforehand.
There are various tutorials online on how to do this, e.g., here.
Yes, that’s correct. Since the Maple bootloader is just application code in flash, all Boot pins to 0 is correct.
You could still be using the wrong drivers though. Can you download and open Zadig (https://zadig.akeo.ie/) and select the Maple DFU device? There should be two interfaces, one for UART and one for USB DFU. The USB DFU interface should have libusb-win32 drivers loaded.
I should have installed the drivers with Zadig, tomorrow I’ll try to check that here in Italy it’s evening :-). I’ll update you tomorrow and see if I installed the correct drivers, thanks again
Good morning,
-I tried to update all the drivers with Zadig,
-I put the bootloader generic_boot20_pc13.bin loaded with stlink v2
-I tried to load but it gives me the same error
The port com me find it
I also tried webUsbDfu
I tried selecting the right port but this comes up
No, it’s not supposed to be just a serial. There’s supposed to be a serial and USB DFU device. You only have one.
Can you erase the flash of your microcontroller again completely with the ST-Link (and STM32CubeProg or whatever) and reflash the bootloader_only_binaries/generic_boot20_pc13.bin?
nothing, I tried to do what you tell me but it doesn’t work.
I tried to load this bootloader and something strange happens:
-I load the bootloader stm32f1_dfu.bin
-it is recognized by Stm32CubeProgrammer or by WebUsb DFU
-I load the firmware compiled by visualstudio
-but after this step the DFU is no longer found…is it possible that my firmware will overwrite the bootloader “stm32f1_dfu.bin”?
