Hi Everyone !
I’m a newbie here and I would like to begin to work with an Arduino Uno Board.
But I meet some issues with the debug tools.
My setup :
- VS Code :
Version: 1.65.2 (user setup)
Commit: c722ca6c7eed3d7987c0d5c3df5c45f6b15e77d1
Date: 2022-03-10T14:33:55.248Z
Electron: 13.5.2
Chromium: 91.0.4472.164
Node.js: 14.16.0
V8: 9.1.269.39-electron.0
OS: Windows_NT x64 10.0.19043 - Platform io version :
Core 5.2.5 - Home 3.4.1 - OS : Microsoft Windows [version 10.0.19043.1586]
I have used the project example arduino-blink to test.
I use only the “simulator mode” while debug (no board connected + PIO Debug Without Uploading)
Using the default debug tool (avr-stub)
Starting the debugging (F5)
1st pass
AVAILABLE: arduino
Looking for upload port...
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
2nd pass
Reading symbols from c:\_TMP\PlatformIO\Projects\220328-011642-arduino-blink\.pio\build\uno\firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
3rd pass
done.
:3333: The system tried to join a drive to a directory on a joined drive.
Using the debug tool (simavr)
Precondition : There is 3 breakpoints in the Blink.cpp file (setup line 12, loop line 18 and 22)
1st pass
1st pass
done.
PlatformIO: debug_tool = simavr
0x00000000 in __vectors ()
warning: Can not parse XML memory map; XML support was disabled at compile time
Temporary breakpoint 1 at 0x440: file C:\.platformio\packages\framework-arduino-avr\cores\arduino/main.cpp, line 35.
Loading section .text, size 0x45e lma 0x0
Start address 0x0, load size 1118
Transfer rate: 8944 bits in <1 sec, 186 bytes/write.
PlatformIO: Resume the execution to `debug_init_break = tbreak main`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
1, main () at C:\.platformio\packages\framework-arduino-avr\cores\arduino/main.cpp:35
35 init();
Run (F5) next breakpoint Blink.cpp setup (line 12)
Run (F5) next breakpoint Blink.cpp loop (line 18)
Run (F5) next breakpoint Blink.cpp loop (line 22) after about 20 seconds
Run (F5) next breakpoint Blink.cpp loop (line 18) after about 20 seconds
Stop (Shift+F5)
Restart (Ctrl+Shift+F5) next breakpoint Blink.cpp loop (line 18)
Run (F5) next breakpoint main.cpp file (line 35)
Run (F5) Always run…
2nd pass and more
done.
Breakpoint
3, loop () at src/Blink.cpp:18
18 digitalWrite(LED_BUILTIN, HIGH);
Then
If I change again the debug tool (go to 1) Using the default debug tool (avr-stub)), I will meet the same error message sequence.
