Hello! Thanks in advance!
I am having the same error as this post except I am on a Raspberry pi 4 with a blank boot of Rasbian. I am trying to build a quick and dirty over the air update system for a project on a Teensy 4.0.
I made sure to enable UART in config.txt and in raspy-config, and I tried all of the suggested commands from the thread:
sudo adduser pi dialout
sudo usermod -a -G dialout pi
and yet I still get this message when I try to install my program:
**pi@raspberrypi** : **~/Documents/Visualisd $** pio run --target upload
Processing **teensy36** (platform: teensy; board: teensy36; framework: arduino)
CONFIGURATION:
PLATFORM: Teensy 4.11.0 > Teensy 3.6
HARDWARE: MK66FX1M0 180MHz, 256KB RAM, 1MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy 1.153.0 (1.53)
- tool-teensy 1.21.1
- toolchain-gccarmnoneeabi 1.50401.0 (5.4.1)
LDF: Library Dependency Finder ->
Found 90 compatible libraries
|-- <arduinoFFT> 1.5.5
|-- <OctoWS2811> 1.4
Linking .pio/build/teensy36/firmware.elf
Checking size .pio/build/teensy36/firmware.elf
Building .pio/build/teensy36/firmware.hex
RAM: [ ] 4.3% (used 11212 bytes from 262144 bytes)
Flash: [ ] 1.5% (used 16136 bytes from 1048576 bytes)
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-cli
Rebooting...
Uploading .pio/build/teensy36/firmware.hex
Teensy Loader, Command Line, Version 2.1
Read ".pio/build/teensy36/firmware.hex": 16148 bytes, 1.5% usage
Unable to claim interface, check USB permissions
Error opening USB device: could not claim interface 0: Operation not permitted
Waiting for Teensy device...
(hint: press the reset button)
Thanks for any help you can offer!
Thanks for any help you can offer!hanks for any help you can offer!
