I managed to download PlatformIO core into my Nvidia TX2 board running ubuntu 16.04. I can compile the sample blink code but when I want to upload the code to the Arduino Uno connected to the board it fails!
Here is the output for “platofrmio run”
nvidia@tegra-ubuntu:~/Documents/pio_project$ platformio run
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR > Arduino Uno
HARDWARE: ATMEGA328P 16MHz 2KB RAM (31.50KB Flash)
Collected 5 compatible libraries
Checking size .pioenvs/uno/firmware.elf
DATA: [ ] 0.4% (used 9 bytes from 2048 bytes)
PROGRAM: [ ] 2.9% (used 930 bytes from 32256 bytes)
========================================================================== [SUCCESS] Took 1.86 seconds ==========================================================================
This is the output for the upload command:
nvidia@tegra-ubuntu:~/Documents/pio_project$ platformio run -e uno -t upload -v
MethodWrapper(["checkprogsize"], [".pioenvs/uno/firmware.elf"])
.pioenvs/uno/firmware.elf :
section size addr
.data 0 8388864
.text 930 0
.bss 9 8388864
.comment 17 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 64 0
.debug_info 1798 0
.debug_abbrev 1482 0
.debug_line 258 0
.debug_str 520 0
Total 5142
<lambda>(["upload"], [".pioenvs/uno/firmware.hex"])
AVAILABLE: arduino
BeforeUpload(["upload"], [".pioenvs/uno/firmware.hex"])
Auto-detected: /dev/ttyACM0
*** [upload] Connection timed out
=========================================================================== [ERROR] Took 16.43 seconds ===========================================================================
Here is the configuration in the platformio.ini file:
[env:uno]
board = uno
I have tried the upload command without the “-e uno” option but it gives the same result.
Also I have copied the proper rule file(udev ) files to /etc/udev/rules.d/
Any idea what is wrong?
