I’m having trouble with compiling a project. The build command will initially work and report all of the errors that it finds - no problem.
But when I try to resolve the problems, I eventually get to the point where the build icon no longer does anything. This is where progress stops and even when I remove any changes that I have made, the build command will no longer work. ![]()
I trust someone can tell me what I am doing wrong…
I have simple code that essentially does nothing
#include <ArduinoMqttClient.h>
When I try building it, it produces
* Executing task: C:\Users\Peter's Workshop\.platformio\penv\Scripts\platformio.exe run
----------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (6.1.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20007.0 (2.0.7)
- tool-esptoolpy @ 1.40500.0 (4.5.0)
Found 33 compatible libraries
Compiling .pio\build\esp32dev\src\main.cpp.o
src/main.cpp:2:10: fatal error: ArduinoMqttClient.h: No such file or directory
* Looking for ArduinoMqttClient.h dependency? Check our library registry!
* CLI > platformio lib search "header:ArduinoMqttClient.h"
* Web > https://registry.platformio.org/search?q=header:ArduinoMqttClient.h
compilation terminated.
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
I edit the include path and get no change, so I add lib_deps to platformio.ini, as follows
; Library options
arduino-libraries/ArduinoMqttClient@^0.1.7
which produces the following error
Error: Invalid 'C:\Users\Peter's Workshop\Documents\MicroProcessor Stuff\Sketches\Under Development\Tests and Trials\Sample\platformio.ini' (project configuration file): 'Source contains parsing errors: "C:\\Users\\Peter's Workshop\\Documents\\MicroProcessor Stuff\\Sketches\\Under Development\\Tests and Trials\\Sample\\platformio.ini"
[line 16]: 'arduino-libraries/ArduinoMqttClient@^0.1.7''
and now the build icon stops working and even when I remove my platformio.ini changes, the build still does not work.
I cannot progress further. It appears there’s a formatting error in platformio.ini. Is that correct? I cannot see it.
