PlatformIO AWS Cloud9 setup
I would like to know how to setup PlatformIO on AWS Cloud9 IDE. I followed the instructions on this link:
https://docs.platformio.org/en/latest/integration/ide/cloud9.html
But it seems to be outdated and I get a bash error after I install the PlatformIO on Cloud9 and try to login to PIO Remote.
Please advise
Thank you
…And what exactly is the content of that error message?
cloud9
Please see attached
Seems like installing PlatformIO via the
sudo python -c "$(curl -fsSL https://raw.githubusercontent.com/platformio/platformio/develop/scripts/get-platformio.py)"
command only makes it available for sudo – can you try executing it without sudo?
I tried. The same result . see below attached image
cloud9_@
Okay, first you should uninstall the root-installed platformio version again with sudo pip remove platformio as to not have two PIO versions.
Then I guess there’s no way around doing what the text output shows: Adding PIO to the path. As the linked docs Redirecting... explain, try and execute
export PATH=$PATH:~/.platformio/penv/bin
and retry the pio command.
