I am trying to upload to a custom board (to a STM32F072) using a STLINK-V3PWR, but it fails with the following openocd error message:
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
using the STM32CubeProgrammer software works for connecting to the target and uploading code:
I assume this is because the OpenOCD version used by platformio does not support the STLINK-V3PWR yet - if this post on the ST community forums is to be believed. I tried manually setting upload_protocol, upload_port and debug_tool in platformio.ini, but this did not fix the issue.
(I did pio pkg update my installation before)
