Platformio 8051 --model-medium linker err
hello, everyone
I want compile 8051 MCU with medium model in platformio,but link fail.please help me and think very much.
my platfromio.ini is list as follow:
[env:ch552]
platform = intel_mcs51
board = ch552
  --model-medium
  --LC:/Users/caoyf/.platformio/packages/toolchain-sdcc/lib/medium
  -IC:/Users/caoyf/Documents/PlatformIO/Projects/ch552_gpio/src/Driver/inc
  -Isrc/PLAT/inc
link errors is list as follow:
Linking .pio\build\ch552\firmware.hex
?ASlink-Warning-Conflicting sdcc options:
   "-mmcs51 --model-medium" in module "main" and
   "-mmcs51 --model-small" in module "_divulong".
   "-mmcs51 --model-small" in module "_moduint".
   "-mmcs51 --model-small" in module "_divuint".
   "-mmcs51 --model-small" in module "_gptrget".
   "-mmcs51 --model-small" in module "_modsint".
   "-mmcs51 --model-small" in module "_divsint".
   "-mmcs51 --model-small" in module "_startup".
*** [.pio\build\ch552\firmware.hex] Error 1
it seems that linker use the lib file in .platformio\packages\toolchain-sdcc\lib\small not the link file in .platformio\packages\toolchain-sdcc\lib\medium,how can i correct it?
I don’t see that board in platform-intel_mcs51/boards at develop · platformio/platform-intel_mcs51 · GitHub. Did you add this yourself?
Yes, I add this myself. The following is the .json file:
  "build": {
    "f_cpu": "24000000",
    "size_iram": 256,
    "size_xram": 1024,
    "size_code": 14336,
    "size_heap": 128,
    "mcu": "ch552t",
    "cpu": "mcs51"
  "frameworks": [],
  "upload": {
    "maximum_ram_size": 1280,
    "maximum_size": 14336,
    "protocol": "stcgal",
    "stcgal_protocol": "stc15",
    "protocols": [
      "stcgal"
  "name": "Generic CH552",
  "url": "http://www.wch.cn/product/CH552.html",
  "vendor": "WCH"
ch552 is a cheap 8051 MCU made in China with USB support.
The linker flags need to include --model-medium, too, otherwise it assumes small by default.
Please add the line
extra_scripts = link_medium.py
to your platformio.ini and, in the project folder at the same level of the platformio.ini, the file link_medium.py with the content
Import("env")
env.Append(LINKFLAGS=["--model-medium"])
Think you very much!
it sovle my problems.
Sincere wishes from faraway China, Happy New Year!
新年快乐!
It should be -LC:/Users/caoyf/.platformio/packages/toolchain-sdcc/lib/medium but not --L to link lib
