from the documentation Redirecting... it is possible to use a development version from git + a specific commit, is it also possible to use more than one commit?
âŚWhat is it supposed to do when it gets two commit hashes? Combine the two versions? oO
When you specify a commit as the point in history to use, it does mean âuse the code as of this commit, inclusive of all prior commitsâ⌠so if that is what you mean by âmore than one commitâ, yeah, sure, you can do that⌠but you canât say âuse this platform (as of what version/commit?!) + these two random commitsâ because, well, for starters, what do you want to happen when there are conflicts?
platformio could shown an error message in case of merge conflict and if the users wants to solve them he could do it
Could, but I bet it wonât happen. To my mind, this would go against the whole idea of your platformio.ini
configuring your project so that itâs transferable to another system⌠if itâs interactive, and the user can make a different choice which then breaks something, then itâs not repeatable/transferable. If that sort of thing was wanted, it would probably be better to have a git folder that is already configured and just pull from that. Then again, Iâm just one of many users, so if more people want that sort of feature, and it was feasible, it might happen!
yep, I agree, not portable. Maybe it could just throw an error in case of a merge conflict, otherwise everything would go well and it would be portable
@pfeerick do you know to specify a custom folder as you suggested?
from the docs Redirecting... it seems that only https://github.com/platformio/platform-*
links are supported.
How can I set platform
to, for example, to esp32 master/branch/commit?
The platformio.ini platform
parameter syntax includes tags,branch,commits⌠i.e. the docs indicate, the same format as platformio platformio install
is valid for platform =
platformio platform install <repository#tag>
(âtagâ can be commit, branch or tag)
But that doesnât help you. What about the following?
platform_packages =
; use upstream Git version
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
It overrides just the framework package, which should do what you want.
yes, overriding only the framework seems the best idea, I guess I can point also to other repo. In case I need to do some tests I could fork the framework and change what I need for example:
platform_packages =
framework-arduinoespressif32 @ https://github.com/aster94/arduino-esp32.git
