Hi, I using GitHub actions with pio ci on my repository.
For most projects, it’s easy and works fine.
I have a problem with project with ESP and C++17.
In platformio.ini I have something like this:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
platform_packages =
mcspr/toolchain-xtensa@~5.100200.0
framework-arduinoespressif8266 @ https://github.com/esp8266/Arduino.git
When I run this, everything is installed correctly and build positive. But when I try this in the console:
pio pkg install -p "espressif8266" -p "mcspr/toolchain-xtensa@~5.100200.0" -p "framework-arduinoespressif8266@https://github.com/esp8266/Arduino.git"
I got error:
Error: Could not find the package with ‘mcspr/toolchain-xtensa @ ~5.100200.0’ requirements for your system ‘windows_amd64’
And the same on CI GitHub Actions.
Is any solution for that?
As you can see in https://registry.platformio.org/tools/mcspr/toolchain-xtensa/compatibility, the author does not provide this package for Windows, only MacOs. That’s a third-party (not released by PlatformIO staff) package, so the best you can do is ask the original author (mcspr (Max Prokhorov) · GitHub) to update.
However, PlatformIO has this package too: PlatformIO Registry
So why not use
platform_packages =
platformio/toolchain-xtensa@~2.100200.0
instead? (Or just ~2.100300.0
for that matter, it’s the most recent one…)
But when I run my project with mention pilafromio.ini with mcspr/toolchain-xtensa@~5.100200.0 it work (I have Windows).
I try with platformio/toolchain-xtensa but same effect:
Error: Could not find the package with ‘platformio/toolchain-xtensa @ ~5.100300.0’ requirements for your system ‘windows_amd64’
I overlocked that 5.100300.211127+darwin
exists. What happens when you use
mcspr/toolchain-xtensa@5.100300.211127
You did not properly copy-paste what I have posted above. It’s not 5.100300.0
it’s 2.100300.0
for the latest 10.3.0 version for the platformio/
releases.
Yes, thx, wrong copy/paste. Project work when I use that in platfromio.ini.
But still when I try:
pio pkg install -p “espressif8266” -p “platformio/toolchain-xtensa@~2.100300.0” -p “framework-arduinoespressif8266@GitHub - esp8266/Arduino: ESP8266 core for Arduino”
I got
Error: Could not find the package with ‘platformio/toolchain-xtensa @ ~2.100300.0’ requirements for your system 'windows_amd64
And on CI I use ubuntu, there I got:
Error: Could not find the package with ‘platformio/toolchain-xtensa @ ~2.100300.0’ requirements for your system ‘linux_x86_64’
-p
is for platform. The toolchain is a tool, use -t
pio pkg install -g -p "espressif8266" -t "platformio/toolchain-xtensa@~2.100300.0" -t "https://github.com/esp8266/Arduino.git"
executes just fine on my machine.
Platform Manager: Installing espressif8266
Platform Manager: espressif8266@3.2.0 has been installed!
Tool Manager: Installing platformio/toolchain-xtensa @ ~2.100300.0
Tool Manager: toolchain-xtensa@2.100300.210717 has been installed!
Tool Manager: Installing platformio/tool-esptool @ <2
Tool Manager: tool-esptool@1.413.0 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.30000.0
Tool Manager: tool-esptoolpy@1.30000.201119 has been installed!
Tool Manager: toolchain-xtensa@2.100300.210717 is already installed
Tool Manager: Installing git+https://github.com/esp8266/Arduino.git
Tool Manager: framework-arduinoespressif8266@3.1.0-dev+sha.b080c50 has been installed!
But you don’t need to execute pio pkg install
commands when the CI just uses the platformio.ini
of the project. pio run
will already install it.
Ok, It’s starting looking good
thx!
