I am using ESP32 Dev Module.
When I am adding ESPAsyncWebServer.h I get this error while building:
Compiling .pio/build/esp32dev/esp-idf/src/main.cpp.o
Generating LD script .pio/build/esp32dev/esp32_out.ld
Generating partitions .pio/build/esp32dev/partitions.bin
Compiling .pio/build/esp32dev/esp-idf/app_trace/app_trace.c.o
Compiling .pio/build/esp32dev/esp-idf/app_trace/app_trace_util.c.o
Compiling .pio/build/esp32dev/esp-idf/app_trace/host_file_io.c.o
Compiling .pio/build/esp32dev/esp-idf/app_trace/gcov/gcov_rtio.c.o
In file included from src/main.cpp:14:
.pio/libdeps/esp32dev/ESP Async WebServer_ID306/src/ESPAsyncWebServer.h:38:2: error: #error Platform not supported
Compiling .pio/build/esp32dev/esp-idf/app_update/esp_ota_ops.c.o
Compiling .pio/build/esp32dev/esp-idf/app_update/esp_app_desc.c.o
In file included from .pio/libdeps/esp32dev/ESP Async WebServer_ID306/src/ESPAsyncWebServer.h:462,
.pio/libdeps/esp32dev/ESP Async WebServer_ID306/src/AsyncWebSocket.h:29:10: fatal error: ESPAsyncTCP.h: No such file or directory
This is my platformio file:
framework = arduino, espidf
build_flags = -DCONFIG_WIFI_SSID=\"ESP_AP\" -DCONFIG_WIFI_PASSWORD=\"MYPASS\"
platform_packages =
; use a special branch
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#idf-release/v4.0
# using the latest stable version
ESP Async WebServer
AsyncTCP
SHA-1 Hash
When I remove espidf as a framework in the platform.ini file it builds successfully for some reason.
Not sure why it says unsupported platform.
