Platform Io not working on termux
$ ls ~/.platformio/packages/toolchain-xtensa-esp32/bin/
xtensa-esp32-elf-addr2line xtensa-esp32-elf-elfedit xtensa-esp32-elf-gcov-dump xtensa-esp32-elf-objcopy
xtensa-esp32-elf-ar xtensa-esp32-elf-g++ xtensa-esp32-elf-gcov-tool xtensa-esp32-elf-objdump
xtensa-esp32-elf-as xtensa-esp32-elf-gcc xtensa-esp32-elf-gdb xtensa-esp32-elf-ranlib
xtensa-esp32-elf-c++ xtensa-esp32-elf-gcc-8.4.0 xtensa-esp32-elf-gdb-add-index xtensa-esp32-elf-readelf
xtensa-esp32-elf-c++filt xtensa-esp32-elf-gcc-ar xtensa-esp32-elf-gprof xtensa-esp32-elf-size
xtensa-esp32-elf-cc xtensa-esp32-elf-gcc-nm xtensa-esp32-elf-ld xtensa-esp32-elf-strings
xtensa-esp32-elf-cpp xtensa-esp32-elf-gcc-ranlib xtensa-esp32-elf-ld.bfd xtensa-esp32-elf-strip
xtensa-esp32-elf-ct-ng.config xtensa-esp32-elf-gcov xtensa-esp32-elf-nm
~/esp $ pio run
Processing espwroom32 (platform: espressif32; board: esp32dev; framework: arduino)
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (6.12.0) > Espressif ESP32 Dev Module
  • framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
  • tool-esptoolpy @ 2.40900.250804 (4.9.0)
  • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Found 33 compatible libraries
Scanning dependencies…
Compiling .pio/build/espwroom32/src/main.cpp.o
Building .pio/build/espwroom32/bootloader.bin
Generating partitions .pio/build/espwroom32/partitions.bin
sh: 1: xtensa-esp32-elf-g++: not found
esptool.py v4.9.0
Creating esp32 image…
Merged 1 ELF section
Compiling .pio/build/espwroom32/FrameworkArduino/Esp.cpp.o
*** [.pio/build/espwroom32/src/main.cpp.o] Error 127
*** [.pio/build/espwroom32/FrameworkArduino/Esp.cpp.o] Error 127
============================================= [FAILED] Took 1.80 seconds =============================================
simply problem is reported. But source is termux cant run try run it from cmd line directly and will see why. Only python works here = no pio builds.
We have already had that discussion in
You can check the answers here Failing to compile using pio in termux
