I tried opening and uploading a project i got from someone else and got this error:
UnknownPackageError: Could not find the package with ‘toolchain-xtensa32 @ ~2.80200.0’ requirements for your system ‘windows_amd64’
I tried a few things i read on forums but nothing worked for me so far.
When i try installing it manually, it tells me that xtensa is already installed.
Does anyone have an idea what i could do to fix this?
The 8.2.0 package does not exist (anymore?), only 8.4.0. See https://registry.platformio.org/tools/platformio/toolchain-xtensa32/versions. What platformio.ini are you using? This should only appear in very outdated platform-espressif32 installations. Because nowadays, the pacakge espressif/toolchain-xtensa-esp32 is used instead.
Hi max,
My platformio.ini looks like this:
board_build.partitions = custompart.csv
platform = espressif32@1.12.4
framework = espidf
upload_port = COM3
monitor_port = COM3
I’m not too familiar with esp’s or platformio in general so i don’t really have a clue on how to resolve this…
Okay that’s ancient in todays terms, released “Jun 17, 2020” originally. PlatformIO broke compatibility by deleting that 8.2.0 package.
Can you add
platform_packages =
toolchain-xtensa32@~2.80400.0
in the platformio.ini to try and get it to use an existing compiler package?
Well it worked so far with this one, but now it’s got a problem with my local windows username having a whitespace in it…
Older platforms indeed used to have a problem with that. The other path is ofc seeing if you can’t upgrade the platform to a more recent one, e…g, at least espressif32@3.5.0.
Hmm and how could i do that?
You change the version in this platformio.ini to one I suggested.
So i tried this solution but i now got the error
Tool Manager: Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch2
UnknownPackageError: Could not find the package with 'espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch2' requirements for your system 'windows_amd64'
CC @ivankravets, the espressif32 platform version 3.5.0 which is the last one to reference the still often-used 1.0.6 Arduino-ESP32 core has dead packages.
What is the reason that you use 3-year-old development platform? If your project depends on ESP-IDF 4, please use the latest stable 5.3.0 version Release 5.3.0 · platformio/platform-espressif32 · GitHub
Change your configuration to:
platform = espressif32@^5
framework = espidf
upload_port = COM3
monitor_port = COM3
Next, in VSCode, click on the PlatformIO icon on the left activity bar > Project Tasks > Dependencies > Update. Build project.
Thanks @ivankravets for your reply,
I got the project from someone else and should set it up on my computer now. I tried your solution but now got the error:
Error: Detected a whitespace character in project paths.
The problem seems to be the whitespace in my local windows username…
Is there a solution or should i just make a temporary user on my pc?
This is the error from ESP-IDF. It does not support projects where the canonical path contains the space.
Could you try to move your project somewhere where there is no space in the path? For example, C:\Projects?
I tried this but the problem seems to be the platformio config… can i move that folder too?
The terminal process "C:\Users\Noe Steiner\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Yes, please do the following steps:
- Close VSCode
- Remove
- Create
C:\.platformio empty folder
- Start VSCode.
The PlatformIO Core should be installed in the C:\.platformio.
Thank you so much! It works now!
