Hello, I hope this is the correct place to post this.
I have an ESP32-WROOM-32U. I am using Platform.io to program it and here is my conf (sorry INI code refuses to format correctly):
board_build.flash_mode = qio
lib_deps = bblanchon/ArduinoJson@^6.17.3
build_flags = -D CORE_DEBUG_LEVEL=5 ; show me all the things!
This builds, and the code runs on the esp32 RIGHT after flash. If I cut power and re-power the chip, I get:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x23 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
This happens ONLY when using Platform.io, Using the Arduino IDE does not cause this issue.
I am guessing it has something to do with my config, but have no clue where to start looking.
This is what I see when I flash using the Arduino IDE:
Sketch uses 216321 bytes (6%) of program storage space. Maximum is 3145728 bytes.
Global variables use 15524 bytes (4%) of dynamic memory, leaving 312156 bytes for local variables. Maximum is 327680 bytes.
esptool.py v2.6
Serial port /dev/ttyUSB0
Connecting.....
Chip is ESP32D0WDQ5 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
MAC: e8:68:e7:08:74:04
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4036.8 kbit/s)...
Hash of data verified.
Flash params set to 0x024f
Compressed 17392 bytes to 11186...
Wrote 17392 bytes (11186 compressed) at 0x00001000 in 0.1 seconds (effective 965.4 kbit/s)...
Compressed 216432 bytes to 110815...
Wrote 216432 bytes (110815 compressed) at 0x00010000 in 1.7 seconds (effective 1011.8 kbit/s)...
Compressed 3072 bytes to 118...
Wrote 3072 bytes (118 compressed) at 0x00008000 in 0.0 seconds (effective 1515.6 kbit/s)...
Leaving...
Hard resetting via RTS pin...
And with that, everything is great.
Any help would be greatly appreciated
Please help me
Thank you very much!
-Kevin
