kwinz
August 23, 2018, 1:40pm
1
I get this error from PIO right after compilation when trying to run in debug mode:
ResetHandler () at C:\Users\Markus\.platformio\packages\framework-arduinoteensy\cores\teensy3\mk20dx128.c:767
767 while (dest < &_edata) *dest++ = *src++;
Not implemented stop reason (assuming exception): undefined
.pioinit:14: Error in sourced command file:
Undefined command: "loop". Try "help".
Any ideas how to fix? Thanks in advance!
Could you provide platformio.ini
kwinz
August 23, 2018, 7:49pm
3
Sure! Thank you!
platformio.ini
[env:teensy32]
platform = teensy
board = teensy31
upload_protocol = jlink
debug_tool = custom
debug_port = :2331
debug_init_break = loop
debug_init cmds =
target remote $DEBUG_PORT
file "$PROG_PATH"
load "$PROG_PATH"
$INIT_BREAK
monitor reset
monitor halt
debug_server =
JLinkGDBServerCL.exe
-singlerun
-if
SWD
-select
USB
-port
2331
-device
MK20DX256xxx7
extra_scripts = extra_script.py
extra_script.py
Import("env")
UPLOAD_JLINK_CONF = env.subst("$BUILD_DIR/upload.jlink")
def _generate_aux(*args, **kwargs):
with open(UPLOAD_JLINK_CONF, "w") as fp:
fp.write("""
h
r
h
loadfile %s
r
q
""" % env.subst("$BUILD_DIR/firmware.hex").replace("\\", "/"))
env.AddPreAction(
"upload",
env.VerboseAction(_generate_aux, "Creating auxiliary files"))
env.Replace(
UPLOADHEXCMD=
'JLink -device MK66FX1M0xxx18 -speed 4000 -if swd -autoconnect 1 -CommanderScript %s' % UPLOAD_JLINK_CONF
Please check documentation for debug_init_break
option. What does mean “loop”? Which type of breakpoint would you like to set? Temporary? Hardware? For example, temporary breakpoint for “loop” has the next GDB syntax: tb loop
kwinz
August 27, 2018, 2:54pm
5
This works! Sorry I should have RTFM. Not sure how the wrong dubug_init_break command got into my platformio.ini in the first place. Thank you!
