Hi folks!
I have been working with ESP32SvelteKit - now based on pioarduino’s espressi32 platform and arduiino framework - for a couple of months, until I came to a point where the precompiled libraries where not suffiecient as I had to increase the max HTTP header size from 1024 to 2048.
I remembered pioarduino’s awsome hybrid compile feature and tried to get the header size increased by setting CONFIG_HTTPD_MAX_REQ_HDR_LEN to 2048. I did the following changes to the ESP32Sveltekit’s original platformio.ini:
- Added
custom_sdkconfigparam - Added
board_build.embed_txtfilesparam
Final platformio.ini
[platformio]
description = Genius Gateway - A gateway for Hekatron Genius Plus X smoke detectors
data_dir = data
extra_configs =
factory_settings.ini
features.ini
config.ini
default_envs = seeed-xiao-esp32s3
[env]
framework = arduino, espidf
platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.31/platform-espressif32.zip
${factory_settings.build_flags}
${features.build_flags}
${config.build_flags}
-D BUILD_TARGET=\"$PIOENV\"
-D APP_NAME=\"Genius-Gateway\"
-D APP_VERSION=\"0.2.3\"
-D ESP32SVELTEKIT_RUNNING_CORE=0
-D EMBED_WWW
-D SERIAL_INFO
-D CONFIG_ARDUHAL_LOG_COLORS
-D CORE_DEBUG_LEVEL=3
custom_sdkconfig = CONFIG_HTTPD_MAX_REQ_HDR_LEN=2048 ; original 1024
lib_compat_mode = strict
board_build.embed_files = src/certs/x509_crt_bundle.bin
board_build.embed_txtfiles =
managed_components/espressif__esp_insights/server_certs/https_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_mqtt_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_claim_service_server.crt
managed_components/espressif__esp_rainmaker/server_certs/rmaker_ota_server.crt
board_ssl_cert_source = mozilla
monitor_filters =
esp32_exception_decoder
log2file
extra_scripts =
pre:scripts/generate_enums.py
pre:scripts/build_interface.py
pre:scripts/generate_cert_bundle.py
scripts/merge_bin.py
scripts/rename_fw.py
scripts/save_elf.py
ArduinoJson@>=7.0.0
elims/PsychicMqttClient@^0.2.3
[env:seeed-xiao-esp32s3]
board = seeed_xiao_esp32s3 ; 8 MB flash, 8 MB PSRAM
When building the project with these changes from scratch, I observed quite a undeterministic behaviour. I get frontend build errors, file not found errors, etc. Every time I just restarted the build, it’s outcome / fail reason slightly changed. Finally, I was left with the following build output:
Terminal output
* Executing task: C:\Users\hmbac\.platformio\penv\Scripts\platformio.exe run
Processing seeed-xiao-esp32s3 (board: seeed_xiao_esp32s3; framework: arduino; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.31/platform-espressif32.zip)
running: generate_enums.py
Generating TypeScript enums from C++ headers...
Processing AlarmBlocker.h...
No enums found
Processing AlarmLinesService.h...
✓ alarm_line_acquisition → AlarmLineAcquisition
Processing cc1101.h...
✓ cc1101_mode → Cc1101Mode
Processing CC1101Controller.h...
No enums found
Processing GatewayDevicesService.h...
✓ genius_alarm_ending → GeniusAlarmEnding
✓ genius_smoke_detector → GeniusSmokeDetector
✓ genius_radio_module → GeniusRadioModule
✓ genius_device_registration → GeniusDeviceRegistration
Processing GatewayMqttSettingsService.h...
No enums found
Processing GatewaySettingsService.h...
No enums found
Processing GeniusGateway.h...
✓ genius_packet_type → GeniusPacketType
Processing ThreadSafeService.h...
No enums found
Processing VisualizerSettingsService.h...
No enums found
Processing WSLogger.h...
No enums found
Processing WSLoggerSettingsService.h...
No enums found
Generated 7 TypeScript enum(s) in C:\dev\esp32\platformio\genius-gateway\interface\src\lib\types\enums.ts
Enum Mapping Summary:
C++ Enum → TypeScript Enum Source File
alarm_line_acquisition → AlarmLineAcquisition AlarmLinesService.h
cc1101_mode → Cc1101Mode cc1101.h
genius_alarm_ending → GeniusAlarmEnding GatewayDevicesService.h
genius_smoke_detector → GeniusSmokeDetector GatewayDevicesService.h
genius_radio_module → GeniusRadioModule GatewayDevicesService.h
genius_device_registration → GeniusDeviceRegistration GatewayDevicesService.h
genius_packet_type → GeniusPacketType GeniusGateway.h
✓ TypeScript enums generated successfully
running: build_interface.py
Newest file: 2025-10-03 12:52:19.471231, output file: 2025-10-03 12:51:02.957521
Building interface with npm
npm install
up to date, audited 256 packages in 2s
62 packages are looking for funding
run `npm fund` for details
7 vulnerabilities (3 low, 4 moderate)
To address all issues (including breaking changes), run:
npm audit fix --force
Run `npm audit` for details.
npm run build
> genius-gateway@0.2.0 build
> vite build
12:52:25 [vite-plugin-svelte] WARNING: The following packages have a svelte field in their package.json but no exports condition for svelte.
svelte-focus-trap@1.2.0
Please see https://github.com/sveltejs/vite-plugin-svelte/blob/main/docs/faq.md#missing-exports-condition for details.
vite v5.4.20 building SSR bundle for production...
transforming...
/*! 🌼 daisyUI 5.0.46 */
✓ 397 modules transformed.
rendering chunks...
12:52:31 [vite-plugin-svelte] WARNING: The following packages have a svelte field in their package.json but no exports condition for svelte.
vite v5.4.20 building for production...
transforming...
✓ 505 modules transformed.
rendering chunks...
computing gzip size...
.svelte-kit/output/client/_app/version.json 0.03 kB │ gzip: 0.05 kB
... (removed some output here) ...
.svelte-kit/output/server/index.js 124.42 kB
✓ built in 11.89s
Run npm run preview to preview your production build locally.
> Using @sveltejs/adapter-static
Wrote site to "build"
✔ done
Converting interface to PROGMEM
Converting _app/immutable/nodes/9.js
SSL Cert Store: Certificate bundle downloaded to: ssl_certs\cacert.pem
SSL Cert Store: Parsing certificates from ssl_certs\cacert.pem
C:\dev\esp32\platformio\genius-gateway\scripts\generate_cert_bundle.py:131: CryptographyDeprecationWarning: Parsed a serial number which wasn't positive (i.e., it was negative or zero), which is disallowed by RFC 5280. Loading this certificate will cause an exception in a future release of cryptography.
self.certificates.append(x509.load_pem_x509_certificate(crt.encode(), default_backend()))
SSL Cert Store: Successfully added 146 certificates
SSL Cert Store: Successfully added 146 certificates in total
SSL Cert Store: Successfully created src\certs\x509_crt_bundle.bin
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/seeed_xiao_esp32s3.html
PLATFORM: Espressif 32 (55.3.31) > Seeed Studio XIAO ESP32S3
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- contrib-piohome @ 3.4.4
- framework-arduinoespressif32 @ 3.3.0
- framework-arduinoespressif32-libs @ 5.5.0+sha.129cd0d247
- framework-espidf @ 3.50501.0 (5.5.1)
- tool-cmake @ 4.0.3
- tool-esp-rom-elfs @ 2024.10.11
- tool-esptoolpy @ 5.1.0
- tool-mklittlefs @ 3.2.0
- tool-ninja @ 1.13.1
- tool-scons @ 4.40801.0 (4.8.1)
- toolchain-xtensa-esp-elf @ 14.2.0+20241119
*** Compile Arduino IDF libs for seeed-xiao-esp32s3 ***
*** Add "custom_sdkconfig" settings to IDF sdkconfig.defaults ***
Replace: CONFIG_ESPTOOLPY_FLASHMODE_QIO=y with: CONFIG_ESPTOOLPY_FLASHMODE_QIO=y
Replace: CONFIG_HTTPD_MAX_REQ_HDR_LEN=1024 with: CONFIG_HTTPD_MAX_REQ_HDR_LEN=2048
Warning! Flash memory size mismatch detected. Expected 8MB, found 16MB!
Please select a proper value in your `sdkconfig.defaults` or via the `menuconfig` target!
LDF Modes: Finder ~ chain, Compatibility ~ strict
Found 47 compatible libraries
|-- ArduinoJson @ 7.4.2
|-- PsychicMqttClient @ 0.2.3
*** [.pio\build\seeed-xiao-esp32s3\.pio\build\seeed-xiao-esp32s3\https_server.crt.S.o] Source `.pio\build\seeed-xiao-esp32s3\https_server.crt.S' not found, needed by target `.pio\build\seeed-xiao-esp32s3\.pio\build\seeed-xiao-esp32s3\https_server.crt.S.o'.
================================================================================== [FAILED] Took 78.02 seconds ==================================================================================
Environment Status Duration
seeed-xiao-esp32s3 FAILED 00:01:18.020
============================================================================= 1 failed, 0 succeeded in 00:01:18.020 =============================================================================
* The terminal process "C:\Users\hmbac\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Custom scripts (enum generation, frontend build, SSL cert bundle generation) seem to work fine and the pipeline seems to recognize the custom_sdkconfig settings in the platformio.ini file as well, starting the Arduino IDF libs compilation.
Now to what I could not solve:
Warning! Flash memory size mismatch detected. Expected 8MB, found 16MB! Please select a proper value in your `sdkconfig.defaults` or via the `menuconfig` target!I was not able to properly specifiy 8MB of flash size (board config is 8MB, but somewhere else 16MB seems to be a default value). Changing
sdkconfig.defaultsas proposed seems not helpful, as the file is regenarted with every build.
How do i properly specify 8MB to avoid this warning? -
https_server.crt.Snot found in pio build folder.
Why might this file be missing? I had the file(s) once (no idea what I did to get it) and with the file available the build continued until I was finally left with a linker error. But now, I am not able to overcome even this point.
Any help is highly appreciated! ![]()
Many thanks in advance!
