Hi!
I use:
latest platform io on
esp8266
software serial is 5.3.0
When I compile clean project with softwareSerial library - I have an error. and I don’t understand why. But on Arduino IDE it compiled.
The author of the library refers to the fact that the library passed the tests and works. Unfortunately he does not offer any help.
My platfromio.ini
> [env:esp12e]
> platform = espressif8266
> board = esp12e
> framework = arduino
> lib_deps =
> # Using library Id
> 168
> EspSoftwareSerial@5.3.0
And error:
`In file included from .pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/SoftwareSerial.h:27:0,
from .pio\libdeps\esp12e\EspSoftwareSerial_ID168\src\SoftwareSerial.cpp:23:
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:145:8: error: expected ';' at end of member declaration
T& IRAM_ATTR pushpeek()
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:145:27: error: ISO C++ forbids declaration of 'pushpeek' with no type [-fpermissive]
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:157:10: error: expected ';' at end of member declaration
bool IRAM_ATTR push();
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:157:10: error: redeclaration of 'bool circular_queue<T>::IRAM_ATTR'
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:145:8: note: previous declaration 'T& circular_queue<T>::IRAM_ATTR'
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:157:25: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:164:10: error: expected ';' at end of member declaration
bool IRAM_ATTR push(T&& val);
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:164:10: error: redeclaration of 'bool circular_queue<T>::IRAM_ATTR'
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:164:32: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:171:10: error: expected ';' at end of member declaration
bool IRAM_ATTR push(const T& val)
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:171:10: error: redeclaration of 'bool circular_queue<T>::IRAM_ATTR'
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:171:37: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:253:16: error: expected initializer before 'circular_queue'
bool IRAM_ATTR circular_queue<T>::push()
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:268:16: error: expected initializer before 'circular_queue'
bool IRAM_ATTR circular_queue<T>::push(T&& val)
from src\main.cpp:6:
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src\SoftwareSerial.cpp: In member function 'void SoftwareSerial::enableRx(bool)':
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src\SoftwareSerial.cpp:140:121: error: 'attachInterruptArg' was not declared in this scope
attachInterruptArg(digitalPinToInterrupt(m_rxPin), reinterpret_cast<void (*)(void*)>(rxBitISR), this, CHANGE);
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h: In instantiation of 'circular_queue<T>::circular_queue(size_t) [with T = unsigned char; size_t = unsigned int]':
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src\SoftwareSerial.cpp:58:122: required from here
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:62:5: error: uninitialized reference member 'circular_queue<unsigned char>::IRAM_ATTR' [-fpermissive]
circular_queue(const size_t capacity) : m_bufSize(capacity + 1), m_buffer(new T[m_bufSize])
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h: In instantiation of 'circular_queue<T>::circular_queue(size_t) [with T = unsigned int; size_t = unsigned int]':
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src\SoftwareSerial.cpp:60:170: required from here
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/circular_queue/circular_queue.h:62:5: error: uninitialized reference member 'circular_queue<unsigned int>::IRAM_ATTR' [-fpermissive]
src\main.cpp:96:33: error: no matching function for call to 'SoftwareSerial::SoftwareSerial(int, int, bool, int)'
SoftwareSerial ss(5,10,false,128);
src\main.cpp:96:33: note: candidate is:
In file included from src\main.cpp:6:0:
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/SoftwareSerial.h:47:5: note: SoftwareSerial::SoftwareSerial()
SoftwareSerial();
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/SoftwareSerial.h:47:5: note: candidate expects 0 arguments, 4 provided
src\main.cpp: In function 'void setup()':
src\main.cpp:101:16: error: no matching function for call to 'SoftwareSerial::begin(int)'
ss.begin(9600);
src\main.cpp:101:16: note: candidate is:
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/SoftwareSerial.h:51:10: note: void SoftwareSerial::begin(uint32_t, int8_t, int8_t, SoftwareSerialConfig, bool, int, int)
void begin(uint32_t baud, int8_t rxPin, int8_t txPin = -1,
.pio\libdeps\esp12e\EspSoftwareSerial_ID168\src/SoftwareSerial.h:51:10: note: candidate expects 7 arguments, 1 provided
*** [.pio\build\esp12e\src\main.cpp.o] Error 1
*** [.pio\build\esp12e\lib435\EspSoftwareSerial_ID168\SoftwareSerial.cpp.o] Error 1`
