Pio --upload-port not used with v4
I reproduced this with a build and upload of a minimal hello world nodemcu pio project.
The platformio.ini had the wrong upload_port, but I used --upload-port to override.
This works with pio3 but not with pio4.
How is this done now?
platformio.ini
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
upload_port = /dev/ttyUSB0
Commandline:
pio run --target upload --upload-port /dev/ttyUSB1
  • with pio3 this uploads to ttyUSB1 as I expected.
  • with pio4 this tries to upload to ttyUSB0 and fails.
I can’t reproduce this. Could you provide an output from pio device list?
Actually, I can… with upload_port upload_port = /dev/ttyUSB0 specified in my platformio.ini, running pio run --target upload --upload-port /dev/ttyUSB1 fails… even though the command line specified port is the correct one… so the CLI doesn’t seem to be overriding the platformio.ini specified port.
AVAILABLE: arduino
Looking for upload port...
Use manually specified: /dev/ttyUSB0
*** [upload] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
[pfeerick@asus-h55d bitOfEverything]$ pio device list
/dev/ttyS0
Hardware ID: PNP0501
Description: ttyS0
/dev/ttyUSB1
Hardware ID: USB VID:PID=1A86:7523 LOCATION=1-1.6
Description: USB2.0-Serial
Thanks! This is our bug and has been just fixed. Please re-test with pio upgrade --dev.
Yup, that squashed that :bug: ! Thanks :slight_smile:
