I can reproduce the same error. Even though I have g++ and gcc installed and available in the PATH of a cmd.exe shell, PIO can’t find it. It also doesn’t make a difference if you use a .c or a .cpp file. This has also been reported in g++ not found · Issue #1 · platformio/platform-native · GitHub but with no resolution. @ivankravets, could you have a look at it?
Full log
Mkdir("C:\Users\Maxi\Documents\stackoverflow_testing\.pio\build\Testing")
Found 0 compatible libraries
gcc -o .pio\build\Testing\src\main.o -c -DPLATFORMIO=40100 -Iinclude -Isrc src\main.c
The command "gcc" is either mistyped or could not be found.
*** [.pio\build\Testing\src\main.o] Error 1
[FAILED] Took 1.07 seconds
Just thought I’d mention I get the same also on Windows, when either running a Test task like the OP, or just doing a normal build. Linux is just fine. Windows fails with both cpp and c code.
Output
Linux
> Executing task: platformio run <
Processing Testing (platform: native)
Compiling .pio/build/Testing/src/main.o
Linking .pio/build/Testing/program
================================================ [SUCCESS] Took 0.69 seconds ================================================
> Executing task: platformio test <
Collected 1 items
Processing * in Testing environment
Building...
Testing...
test/main.cpp:11:testOne [PASSED]
1 Tests 0 Failures 0 Ignored
OK
================================================ [PASSED] Took 0.96 seconds ================================================
Test Environment Status Duration
* Testing PASSED 00:00:00.958
================================================ 1 succeeded in 00:00:00.958 ================================================
Windows
> Executing task: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe run <
Compiling .pio\build\Testing\src\main.o
'g++' is not recognized as an internal or external command,
operable program or batch file.
========================================= [FAILED] Took 8.12 seconds =========================================
Mkdir("e:\Projects\PlatformIO\native\unit_test_native\.pio\build\Testing")
'gcc' is not recognized as an internal or external command,
========================================= [FAILED] Took 5.82 seconds =========================================
> Executing task: C:\Users\Peter\.platformio\penv\Scripts\platformio.exe test <
Collected 1 items
Building...
*** [.pio\build\Testing\test\main.o] Error 1
*** [.pio\build\Testing\test\output_export.o] Error 1
*** [.pio\build\Testing\UnityTestLib\unity.o] Error 1
========================================= [FAILED] Took 5.52 seconds =========================================
* Testing FAILED 00:00:05.524
==================================== 1 failed, 0 succeeded in 00:00:05.524 ====================================
Collected 1 items
Building...
* Testing FAILED 00:00:05.515
==================================== 1 failed, 0 succeeded in 00:00:05.515 ====================================
I just re-read the docs, and the penny dropped… Native… and…
This platform uses built-in toolchains […] from particular OS where it will be run.
… i.e. when using native, PlatformIO does not supply the toolchain?
I think that documentation could be improved a bit… especially the rather pointless link to the PIO registry page for more information… which will pretty much point you back to the documentation page… rinse… repeat…
After installing the gcc toolchain via the MinGW Install Manager, C:\MinGW\bin to my path, and restarting VSCode, it works! edit: making that GCC-8.2.0-5.
Then again… perhaps platform = windows_x86 is what was wanted here? As that would have supplied the toolchain… and I see it seems it allows windows development on linux as well (I was going to say that was a bit crazy, but at least that means linux can be used for CI? )
7.2.0 from MinGW, compiler is in the PATH of the system, on Windows x64.
C:\Users\Maxi>g++ --version
g++ (i686-posix-dwarf-rev1, Built by MinGW-W64 project) 7.2.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
C:\Users\Maxi>gcc --version
gcc (i686-posix-dwarf-rev1, Built by MinGW-W64 project) 7.2.0
C:\Users\Maxi>which gcc
C:\Program Files (x86)\mingw-w64\i686-7.2.0-posix-dwarf-rt_v5-rev1\mingw32\bin\gcc.EXE
It shouldn’t depend on the compiler version should it? The error comes from not even finding gcc. It seems like it gets thrown out of the path somehow?
PS C:\Users\danie> g++ --version
g++.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0
Copyright (C) 2018 Free Software Foundation, Inc.
PS C:\Users\danie> gcc --version
gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0
It doesn’t look to be dependent on the version of gcc installed, as @maxgerhardt is having the same problem with a different version
