timb
July 9, 2022, 8:45pm
1
I’m attempting to run a Unity test for my platformio AVR project in VSCODE.
When I run pio test from the command line, I get the following error after successful test upload to my hardware. I also note that adding -vvv does not enable any unity test runner verbosity.
‘UnityTestRunner’ object has no attribute ‘verbose’
Is this a Unity python error? I can’t seem to find the source of the error.
Thanks!
PlatformIO 6.1.1rc1
What’s your exact platformio.ini?
Can you try to get the most recent core version? (CLI + pio upgrade --dev)
timb
July 9, 2022, 9:06pm
3
Thanks for having a look!
% ~/.platformio/penv/bin/pio upgrade --dev
Please wait while upgrading PlatformIO ...
PlatformIO has been successfully upgraded to 6.1.1rc1
Release notes: https://docs.platformio.org/en/latest/history.html```
Here is my platformio.ini
[platformio]
; Default build target
default_envs = run_main_on_hw
[env]
board_build.f_cpu = 1000000L
board_hardware.oscillator = internal
build_unflags =
monitor_speed = 9600
;; ~/.platformio/penv/bin/pio run -e run_main_on_hw -t upload
[env:run_main_on_hw]
platform = atmelmegaavr
board = ATtiny3224
upload_protocol = custom ; --fuses 2:0x02 6:0x04 8:0x00 ; 2:0x01 - 16Mhz, 2:0x02 - 20 Mhz.
upload_port = /dev/tty.usbserial-14230
upload_speed = 115200
upload_command = python3 ~/.platformio/packages/framework-arduino-megaavr-megatinycore/tools/prog.py -t uart -u $UPLOAD_PORT -b $UPLOAD_SPEED -d $BOARD_MCU --fuses 2:0x01 6:0x04 8:0x00 -f$SOURCE -a write
;; ~/.platformio/penv/bin/pio test -e test_on_real_hw
[env:test_on_real_hw]
board = ATtiny3224
build_flags = -DUNITY_CONFIG_HW_TEST
upload_command = python3 ~/.platformio/packages/framework-arduino-megaavr-megatinycore/tools/prog.py -t uart -u $UPLOAD_PORT -b $UPLOAD_SPEED -d $BOARD_MCU -f$SOURCE -a write
test_port = /dev/tty.usbserial-14220
test_speed = 115200
This is reproducable for me too with the simplest possible Arduino Uno + Unity test example.
[env:uno]
board = uno
test\test_simple\test.cpp
#include <unity.h>
void test_calculator_addition(void) {
TEST_ASSERT_EQUAL(32, 25 + 7);
void RUN_UNITY_TESTS() {
UNITY_BEGIN();
RUN_TEST(test_calculator_addition);
UNITY_END();
#ifdef ARDUINO
// NOTE!!! Wait for >2 secs
// if board doesn't support software reset via Serial.DTR/RTS
delay(2000);
RUN_UNITY_TESTS();
digitalWrite(13, HIGH);
delay(100);
digitalWrite(13, LOW);
delay(500);
Output of project task “Verbose Test”
* Executing task: C:\Users\Max\AppData\Local\Programs\Python\Python38\Scripts\platformio.exe test --verbose --environment uno
Collected 1 tests (test_simple)
Processing test_simple in uno environment
Building & Uploading...
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file ".pio\build\uno\firmware.hex"
avrdude: writing flash (3446 bytes):
Writing | ################################################## | 100% 0.55s
avrdude: 3446 bytes of flash written
avrdude: verifying flash memory against .pio\build\uno\firmware.hex:
avrdude: load data flash data from input file .pio\build\uno\firmware.hex:
avrdude: input file .pio\build\uno\firmware.hex contains 3446 bytes
Reading | ################################################## | 100% 0.44s
avrdude: verifying ...
avrdude: 3446 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
Testing...
If you don't see any output for the first 10 secs, please reset board (press reset button)
'UnityTestRunner' object has no attribute 'verbose'
--------------------------------------------------------------------------------------- uno:test_simple [ERRORED] Took 5.84 seconds ---------------------------------------------------------------------------------------
============================== SUMMARY ==============================
Environment Test Status Duration
uno test_simple ERRORED 00:00:05.839
============= 1 test cases: 0 succeeded in 00:00:05.839 =============
CC @ivankravets
Sorry for the issue, fixed in the latest PIO Core-dev version. Please re-run pio upgrade --dev.
Confirmed fixed after doing pio upgrade --dev again.
Testing...
test\test_simple\test.cpp:9:test_calculator_addition:PASS
1 Tests 0 Failures 0 Ignored
OK
------------------------------------------------------------------------------ uno:test_simple [PASSED] Took 8.73 seconds ------------------------------------------------------------------------------
Many thanks!
There are some critical issues in PIO Core 6.1.0. We fixed all of them platformio-core/HISTORY.rst at develop · platformio/platformio-core · GitHub
The PIO Core 6.1.1 is planned for release tomorrow.
timb
July 10, 2022, 6:41pm
8
The upgrade works for me, too.
Many thanks!
