Pio test error: mbed_sdk_boot.c:112: undefined reference to `main'
Hi there!
I’ve set-up a new Visual Studio project for a Teensy 3.2 using:
pio init -b teensy31 --ide visualstudio
The project appears to have configured OK as the Teensy ‘mbed-blinky’ example builds and runs just fine.
However when I tried to run a simple Unity test against it I’m getting the following error:
pio test -vv
Collected 1 tests (*)
Processing * in teensy31 environment
Building & Uploading...
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy31.html
PLATFORM: Teensy (4.16.0) > Teensy 3.1 / 3.2
HARDWARE: MK20DX256 72MHz, 64KB RAM, 256KB Flash
DEBUG: Current (jlink) External (jlink)
 - framework-mbed @ 6.51506.201227 (5.15.6)
 - tool-teensy @ 1.155.0 (1.55)
 - toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Collecting mbed sources...
Found 5 compatible libraries
|-- Unity @ 2.5.2
Building in test mode
Linking .pio\build\teensy31\firmware.elf
.pio/build/teensy31/FrameworkMbed/platform/source/mbed_sdk_boot.o: In function `__wrap_main':
C:\Users\lonney\.platformio\packages\framework-mbed\platform\source/mbed_sdk_boot.c:112: undefined reference to `main'
*** [.pio\build\teensy31\firmware.elf] Error 1
I’m not sure it has anything to do with the contents of the test as even just commenting out everything doesn’t change anything.
Is this something I’ve overlooked, or potentially a bug I need to raise elsewhere?
Thanks!
platformio.ini
[env:teensy31]
platform = teensy
board = teensy31
framework = mbed
board_build.mcu = mk20dx256
board_build.f_cpu = 72000000L
upload_protocol = teensy-cli
PlatformIO Core 6.1.7
Visual Studio Community 2022
Windows 10
Well, does one of your test sources define a main() function? The mbed framework needs it to be present in the firmware.
See platformio-examples/unit-testing/calculator/test/test_common/test_calculator.cpp at develop · platformio/platformio-examples · GitHub
Ah that was it, thanks! I think I accidentally used a testing example meant for Arduino, instead of mbed.
