After a long and exhaustive search on the forums and googling around, i still dont understand why pio builds and compiles the whole marlin folder even when a single fullstop has been changed in any of the underlying files. It takes varying times from 5min - 20min which is soo painful coz i cant get any work done. soo frustrating so therefore am asking for your help.
This is the folder structure of my marlin folder in vscode.
Am compiling for an LPC1768 platform.
Below is what constitutes my platformio.ini file.
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = LPC1768
[common]
default_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
extra_scripts = pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
build_flags = -fmax-errors=5 -g -D__MARLIN_FIRMWARE__ -fmerge-all-constants
LiquidCrystal
TMCStepper@>=0.6.2,<1.0.0
Adafruit NeoPixel
U8glib-HAL=https://github.com/MarlinFirmware/U8glib-HAL/archive/bugfix.zip
Adafruit_MAX31865=https://github.com/adafruit/Adafruit_MAX31865/archive/master.zip
LiquidTWI2=https://github.com/lincomatic/LiquidTWI2/archive/master.zip
Arduino-L6470=https://github.com/ameyer/Arduino-L6470/archive/0.8.0.zip
SailfishLCD=https://github.com/mikeshub/SailfishLCD/archive/master.zip
SailfishRGB_LED=https://github.com/mikeshub/SailfishRGB_LED/archive/master.zip
SlowSoftI2CMaster=https://github.com/mikeshub/SlowSoftI2CMaster/archive/master.zip
# Globally defined properties - inherited by all environments
[env]
build_flags = ${common.build_flags}
lib_deps = ${common.lib_deps}
monitor_speed = 250000
[env:LPC1768]
platform = https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.2.zip
board = nxp_lpc1768
build_flags = -DU8G_HAL_LINKS -IMarlin/src/HAL/LPC1768/include - IMarlin/src/HAL/LPC1768/u8g ${common.build_flags}
# debug options for backtrace
# -funwind-tables
# -mpoke-function-name
lib_ldf_mode = off
lib_compat_mode = strict
extra_scripts = Marlin/src/HAL/LPC1768/upload_extra_script.py
src_filter = ${common.default_src_filter} +<src/HAL/LPC1768>
upload_port = G:
lib_deps = Servo
LiquidCrystal
TMCStepper@>=0.6.1,<1.0.0
Adafruit NeoPixel=https://github.com/p3p/Adafruit_NeoPixel/archive/release.zip
Am using PlatformIO Core 4.4.0a3, Home 3.2.3 and vscode 1.46.1
