Been trying to use PIO Serial Monitor for a long time and never got it to run. Tried all I can think of and I get the following error:
/Users/petertomich/.pyenv/shims/pio device monitor -e CERBERUS-release
error: Traceback (most recent call last):
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/__main__.py", line 103, in main
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/cli.py", line 85, in invoke
return super().invoke(ctx)
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/click/core.py", line 1688, in invoke
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/click/core.py", line 783, in invoke
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/device/monitor/command.py", line 152, in device_monitor_cmd
start_terminal(options)
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/device/monitor/terminal.py", line 54, in start_terminal
term = new_terminal(options)
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/device/monitor/terminal.py", line 102, in new_terminal
term = Terminal(
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/platformio/device/monitor/terminal.py", line 28, in __init__
super().__init__(*args, **kwargs)
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/serial/tools/miniterm.py", line 395, in __init__
self.console = Console()
File "/Users/petertomich/.pyenv/versions/3.11.3/lib/python3.11/site-packages/serial/tools/miniterm.py", line 198, in __init__
self.old = termios.tcgetattr(self.fd)
termios.error: (25, 'Inappropriate ioctl for device')
`python -m pip install -U platformio` command
Running on CLion latest version on latest Mac Ventura 13.5.2 (same problem in previous versions)
So this issues seems to be a plugin issue. I have just updated to CLion 2023.2.2
(Build #CL-232.9921.42, built on September 12, 2023) this morning and it is still there. It happens when you try to run monitor from PIO menu or upload and monitor command. However, when you run monitor directly from the command line (pio device monitor -f esp32_exception_decoder -f default -f log2file -f colorize -f debug), it works fine.
I am seeing the same thing tonight. I am transitioning from VSCode to CLion but having an issue getting the serial monitor to work. Looks like I am getting the same error as was reported here.
