Pio remote commands
Hi everyone, I am new to using PlatformIO. I am having problems with the Remote development functions. I can see the list of remote devices, read the messages transmitted by the serial port of the remote devices, but what I can’t do is upload the code to a remote device.
When I try to upload the code the project is compiled and generated correctly on my local PC, but when I start uploading it to the remote device I get a notification that a file cannot be found. Apparently PlatformIO leave creating any necessary file. Below I attach a screenshot with the error.
Please, can someone help me? Thanks in advance
up
Is the PlatformIO-core up-to-date? Please open a terminal and execute pio upgrade --dev, then retry.
Hi Max, thanks for replying. I was able to execute the commands that I needed using windows command prompt (cmd) executing the code C: \ Users \ user_name \ .platformio \ penv \ Scripts \ platformio.exe followed by the Remote Development commands, I updated PlatformIO-core but neither are the commands executed in the platformio terminal. I was able to solve in the way I tell you but now a new problem has arisen and I have a new question.
So pio remote run --target upload works when executed in the terminal, but not through the “Remove Upload” button?
No, I did not run pio remote run --target upload using code, I just used the remote upload button. I do not think it is a problem with the command, because the Remote Devices and Remote Monitor functions do work correctly, that is, I am able to see the remote device and connect to it to show the messages through the serial port, I can interact with the remote device communicating by serial port, what I can’t do is program it. As I understand the error in the image that I put, the problem must be that the platformio is not creating a file necessary for programming, and therefore this file is not found.
It says exit code 1. Where can I see the platformio error codes? I have searched about error codes but I have not found anything concrete
Sadly the error is too generic to make sense out of it.
You can again open the CLI and post the result of executing
pio remote run --target upload -v
so that we have a verbose log, which might reveal more
ok, I am going to do that, the person who should connect the device and authorize me to access remotely lives in India. He wakes up into about 6 hours (2:00 GMT, 4:00 AM in Germany). When he wakes up I do that test and I upload the results to the forum. Thank you once again for your quick response and dedication. Best regards
I already did the test you told me, the messages in the terminal are the same. I attach a photo below so you can see them, I mark the code line in green. Is there an address in which a .log file is generated with details of the operation to be able to send it to you?
I’m also going to upload a screenshot of my platformio.ini file
remote upload
platini
Now I did another test by setting the verbose parameter and it gave me more details. There I send you what the terminal shows me. I am going to send it to you in two parts because the web limits me the number of characters:
C:\Users\andyt>C:\Users\andyt\.platformio\penv\Scripts\platformio.exe remote run --target upload -v --project-dir "C:\Users\andyt\Desktop\Remote test\Remote\Remote"
Building project locally
Processing due (platform: atmelsam; board: due; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/due.html
PLATFORM: Atmel SAM (6.1.0) > Arduino Due (Programming Port)
HARDWARE: AT91SAM3X8E 84MHz, 96KB RAM, 512KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink, stlink)
 - framework-arduino-sam 1.6.12
 - framework-cmsis 1.40500.0 (4.5.0)
 - framework-cmsis-atmel 1.2.2
Found 3 compatible libraries
|-- <SPI> 1.0 (C:\Users\andyt\.platformio\packages\framework-arduino-sam\libraries\SPI)
arm-none-eabi-g++ -o .pio\build\due\lib8bf\SPI\SPI.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\libraries\SPI\src -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\libraries\SPI\src\SPI.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduinoVariant\variant.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x\variant.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\IPAddress.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\IPAddress.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\Print.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\Print.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\Reset.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\Reset.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\RingBuffer.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\RingBuffer.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\Stream.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\Stream.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\UARTClass.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\UARTClass.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\USARTClass.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USARTClass.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\USB\CDC.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\sysC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp: In function 'void USB_ISR()':
C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp:688:21: warning: this 'else' clause does not guard... [-Wmisleading-indentation]
                     else
teC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp:690:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'else'
m\CMSIS\D         UDD_Send8(EP0, 0);
evi         ^~~~~~~~~
ce\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\CDC.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\USB\PluggableUSB.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\PluggableUSB.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\USB\USBCore.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\USB\USBCore.cpp
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\WInterrupts.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\WInterrupts.c
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\WMath.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\WMath.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\WString.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\WString.cpp
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\abi.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\abi.cpp
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\avr\dtostrf.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\avr\dtostrf.c
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\cortex_handlers.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\cortex_handlers.c
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\hooks.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\hooks.c
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\iar_calls_sam3.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\iar_calls_sam3.c
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\main.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\main.cpp
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\itoa.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\itoa.c
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\new.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\new.cpp
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\syscalls_sam3.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\syscalls_sam3.c
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\watchdog.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\watchdog.cpp
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\wiring_analog.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring_analog.c
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\wiring.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring.c
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\wiring_digital.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring_digital.c
arm-none-eabi-g++ -o .pio\build\due\FrameworkArduino\wiring_pulse.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring_pulse.cpp
arm-none-eabi-gcc -x assembler-with-cpp -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x -c -o .pio\build\due\FrameworkArduino\wiring_pulse_asm.S.o C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring_pulse_asm.S
arm-none-eabi-gcc -o .pio\build\due\FrameworkArduino\wiring_shift.c.o -c -std=gnu11 -Os -ffunction-sections -fdata-sections -Wall -mcpu=cortex-m3 -mthumb -nostdlib --param max-inline-insns-single=500 -DPLATFORMIO=50200 -D__SAM3X8E__ -DARDUINO_SAM_DUE -DARDUINO=10805 -DF_CPU=84000000L -DUSBCON -DUSB_VID=0x2341 -DUSB_PID=0x003E "-DUSB_PRODUCT=\"Arduino Due\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO_ARCH_SAM -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\libsam -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\CMSIS\Include -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\system\CMSIS\Device\ATMEL -IC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x C:\Users\andyt\.platformio\packages\framework-arduino-sam\cores\arduino\wiring_shift.c
arm-none-eabi-g++ -o .pio\build\due\firmware.elf -T flash.ld -Os -mcpu=cortex-m3 -mthumb -Wl,--gc-sections -Wl,--check-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--entry=Reset_Handler -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid .pio\build\due\src\File.cpp.o .pio\build\due\src\NexButton.cpp.o .pio\build\due\src\NexCheckbox.cpp.o .pio\build\due\src\NexCrop.cpp.o .pio\build\due\src\NexDualStateButton.cpp.o .pio\build\due\src\NexGauge.cpp.o .pio\build\due\src\NexGpio.cpp.o .pio\build\due\src\NexHardware.cpp.o .pio\build\due\src\NexHotspot.cpp.o .pio\build\due\src\NexNumber.cpp.o .pio\build\due\src\NexObject.cpp.o .pio\build\due\src\NexPage.cpp.o .pio\build\due\src\NexPicture.cpp.o .pio\build\due\src\NexProgressBar.cpp.o .pio\build\due\src\NexRadio.cpp.o .pio\build\due\src\NexRtc.cpp.o .pio\build\due\src\NexScrolltext.cpp.o .pio\build\due\src\NexSlider.cpp.o .pio\build\due\src\NexText.cpp.o .pio\build\due\src\NexTimer.cpp.o .pio\build\due\src\NexTouch.cpp.o .pio\build\due\src\NexUpload.cpp.o .pio\build\due\src\NexVariable.cpp.o .pio\build\due\src\NexWaveform.cpp.o .pio\build\due\src\SD.cpp.o .pio\build\due\src\main.cpp.o .pio\build\due\src\utility\Sd2Card.cpp.o .pio\build\due\src\utility\SdFile.cpp.o .pio\build\due\src\utility\SdVolume.cpp.o -L.pio\build\due -LC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x\linker_scripts\gcc -LC:\Users\andyt\.platformio\packages\framework-arduino-sam\variants\arduino_due_x -Wl,--start-group .pio\build\due\lib8bf\libSPI.a .pio\build\due\libFrameworkArduinoVariant.a .pio\build\due\libFrameworkArduino.a -lm -lsam_sam3x8e_gcc_rel -lgcc -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pio\build\due\firmware.elf"])
RAM:   [          ]   3.7% (used 3660 bytes from 98304 bytes)
Flash: [          ]   4.0% (used 20960 bytes from 524288 bytes)
.pio\build\due\firmware.elf  :
section            size        addr
.text             20960      524288
.relocate          2244   537329664
.bss               3660   537331908
.ARM.attributes      41           0
.comment            238           0
.debug_frame       1344           0
Total             28487
============================================= [SUCCESS] Took 2.59 seconds =============================================
Uploading firmware remotely
(2, 'CreateProcess', 'The system cannot find the file specified.')
Hm, sadly the verbose output doesn’t have more info regarding the critical upload phase.
3 more things:
  • does the behavior change if you create the project in a folder containing no spaces? (The current path includes "Remote Test")
  • does the behavour change if you run pio remote run --force-remote -t upload in the project directory?
  • what does pio remote device list output?
  • if the first does not help, please file an issue at Issues · platformio/platformio-core · GitHub.
I already did the tests you suggested me and they did not work. In the first, I delete the space in the path and it keeps giving me the same error, the second test did not run correctly either. Regarding the third test, I am able to see the remote device, I can even use the Remote Monitor functionality, that is, I am able to see its serial port messages, what I cannot do is remote programming, I have tried do it even with other projects but it gives me the same error. I sent these projects to him and he is able to test them on his hardware, the only I can’t do is program the device remotely. The device is an Arduino Due.
Below I show you the image with the results of the three tests, each of the tests is enclosed in a green box to delimit them and make it easier for you to see the results.
test2
I see. Please file an issue the PIO core.
ok, i’ll do it. Thank you ver much my friend
