Creating new project in PIO wizard for teensy40 or teensy41 with zephyr framework the wizard report this error popup
PIO Core Call Error: “The current working directory C:\Users\marco\Documents\PlatformIO\Projects\teensy zephyr will be used for the project.\r\n\r\nThe next files/directories have been created in C:\Users\marco\Documents\PlatformIO\Projects\teensy zephyr\r\ninclude - Put project header files here\r\nlib - Put here project specific (private) libraries\r\nsrc - Put project source files here\r\nplatformio.ini - Project Configuration File\r\nResolving teensy40 dependencies…\r\nAlready up-to-date.\r\nUpdating metadata for the vscode IDE…\r\n\n\nError: Processing teensy40 (platform: teensy; board: teensy40; framework: zephyr)\r\n--------------------------------------------------------------------------------\r\nVerbose mode can be enabled via -v, --verbose
option\r\nCONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy40.html\r\nPLATFORM: Teensy (4.17.0) > Teensy 4.0\r\nHARDWARE: IMXRT1062 600MHz, 512KB RAM, 1.94MB Flash\r\nDEBUG: Current (jlink) External (jlink)\r\nPACKAGES: \r\n - framework-zephyr @ 2.20701.220422 (2.7.1) \r\n - tool-cmake @ 3.21.3 \r\n - tool-dtc @ 1.4.7 \r\n - tool-ninja @ 1.9.0 \r\n - toolchain-gccarmnoneeabi @ 1.80201.181220 (8.2.1)\r\nReading CMake configuration…\r\n– Application: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/zephyr\r\n– Zephyr version: 2.7.1 (C:/Users/marco/.platformio/packages/framework-zephyr)\r\n– Found Python3: C:/Users/marco/.platformio/penv/Scripts/python.exe (found suitable exact version "3.9.13") found components: Interpreter \r\n– Board: teensy40\r\n– Cache files will be written to: C:/Users/marco/.platformio/packages/framework-zephyr/.cache\r\n– Found dtc: C:/Users/marco/.platformio/packages/tool-dtc/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")\r\n– Found toolchain: gnuarmemb (C:/Users/marco/.platformio/packages/toolchain-gccarmnoneeabi)\r\n– Found BOARD.dts: C:/Users/marco/.platformio/packages/framework-zephyr/boards/arm/teensy4/teensy40.dts\r\n– Generated zephyr.dts: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/zephyr.dts\r\n– Generated devicetree_unfixed.h: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/include/generated/devicetree_unfixed.h\r\n– Generated device_extern.h: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/include/generated/device_extern.h\r\n– Including generated dts.cmake file: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/dts.cmake\r\nParsing C:/Users/marco/.platformio/packages/framework-zephyr/Kconfig\r\n\r\nLoaded configuration ‘C:/Users/marco/.platformio/packages/framework-zephyr/boards/arm/teensy4/teensy40_defconfig’\r\n\r\nConfiguration saved to ‘C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/.config’\r\n\r\nKconfig header saved to ‘C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/zephyr/include/generated/autoconf.h’\r\n\r\n– The C compiler identification is GNU 8.2.1\r\n– The CXX compiler identification is GNU 8.2.1\r\n– The ASM compiler identification is GNU\r\n– Found assembler: C:/Users/marco/.platformio/packages/toolchain-gccarmnoneeabi/bin/arm-none-eabi-gcc.exe\r\n– Configuring incomplete, errors occurred!\r\nSee also "C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/CMakeFiles/CMakeOutput.log".\r\nSee also "C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/CMakeFiles/CMakeError.log".\r\n\r\nC:\Users\marco\.platformio\packages\toolchain-gccarmnoneeabi\bin\arm-none-eabi-gdb.exe: warning: Couldn’t determine a path for the index cache directory.\r\n\r\nCMake Error: Could not find cmake module file: CMakeDeterminezephyrCompiler.cmake\r\nCMake Error: Error required internal CMake variable not set, cmake may not be built correctly.\r\nMissing variable is:\r\nCMAKE_zephyr_COMPILER_ENV_VAR\r\nCMake Error: Error required internal CMake variable not set, cmake may not be built correctly.\r\nMissing variable is:\r\nCMAKE_zephyr_COMPILER\r\nCMake Error: Could not find cmake module file: C:/Users/marco/Documents/PlatformIO/Projects/teensy zephyr/.pio/build/teensy40/CMakeFiles/3.21.3/CMakezephyrCompiler.cmake\r\nCMake Error at CMakeLists.txt:3 (project):\r\n No CMAKE_zephyr_COMPILER could be found.\r\n\r\n Tell CMake where to find the compiler by setting the CMake cache entry\r\n CMAKE_zephyr_COMPILER to the full path to the compiler, or to the compiler\r\n name if it is in the PATH.\r\n\r\n\r\nCMake Error: Could not find cmake module file: CMakezephyrInformation.cmake\r\nCMake Error: CMAKE_zephyr_COMPILER not set, after EnableLanguage\r\n========================= [FAILED] Took 18.37 seconds =========================”
I can see error updating metadata vs code for teensy and a path error cor cmake, but where i need to set the path?
I don’t understand where i’m wrong
