Hi!
I would like to know why PIO is looking for .py file while compiling a .cpp project.
I’m trying to compile this project: GitHub - universam1/iSpindel: electronic Hydrometer
I’m getting this error:
File "git_rev.py", line 5
print(f'\'-D FIRMWAREVERSION="{version}"\'')
SyntaxError: invalid syntax
OSError: 'python git_rev.py' exited 1:
File "/home/fernandogarcia/.platformio/penv/lib/python3.6/site-packages/platformio/builder/main.py", line 177:
Here a screenshot of VSCode:
Thanks in advance!
Best regards.
The project you’re linking to explicitly tells PlatformIO to execute a python script to get build flags from, as you can see in
This is supported per documentation. Thus the file git_rev.py
which is contained in the repo will be executed
You can see that it uses format-strings (or, f-strings). You seem to be on a Python 3.6 version in which this isn’t supported though
Try upgrading PlatformIO (PIO Home → Quick Access → Update all) or reinstall it, so that it installs itself with a higher Python version. You can also rewrite the f-string expression to a normal string expression, as e.g.
import subprocess
# Get 0.0.0 version from latest Git tag
tagcmd = "git describe --tags"
version = subprocess.check_output(tagcmd, shell=True).decode().strip()
print('\'-D FIRMWAREVERSION="' + str(version) + '"\'')
Hi!
Thanks for your answer @maxgerhardt !
I have upgraded everything and now I’m running Python 3.7.5 but the problem remains.
I did an alias to execute python3 as python.
Running the command bellow from terminal I had the correct answer.
❯ python git_rev.py
'-D FIRMWAREVERSION="6.5.1-11-gf439bc9"'
But running pio run
on terminal or inside of VSCode I got the same compiling error above.
I think PIO is using wrong Python version to compile the code.
Running ~/.platformio/penv/bin/python --version
inside of VSCode I have the correct version it’s Python 3.7.5
Using your suggested syntax works to Python 2.7.17 and 3.7.5.
I’ll send a PR for this project.
There’s anyway to select Python version inside of PIO?
Best regards.
There’s in strange behaviour on PIO.
I did a clone of the project to send a PR and the project is compiled without any error and without changes.
Compiling the project downloaded as zip from Github I have compiling error.
Could someone try reproduce this behaviour?
If I clone the project via git
and compile and build the project, I get no errors whatsoever. But I also only have a Python 3.8.6 version installed, and no Python 2.x version.
Well yes because it executes git describe --tags
but if you download it is a .zip
file, then it’s not a git repository anymore in which git
commands can be executed – it’s just a plain folder. Hence the execution errors out, this makes sense.
Of course, the Python script could be a bit better there and check if the project folder isn’t an initialized git repository at all…
Hi!
In fact the compiling error for files from zip folder is:
fatal: not a git repository (or any of the parent directories): .git
File "git_rev.py", line 4, in <module>
File "/usr/lib/python3.7/subprocess.py", line 411, in check_output
**kwargs).stdout
File "/usr/lib/python3.7/subprocess.py", line 512, in run
output=stdout, stderr=stderr)
The error about syntax disappears after specify python version in build_flags
build_flags = !python3 git_rev.py
Thank you for your help.
Best regards.
