.pio/libdeps being included in cppcheck static checks
I am running the Platformio static checking using pio check --skip-packages -e esp32 and files in .pio/libdeps are being included in the output and polluting it (it’s surprising how many warnings these libraries have!).
My platformio.ini is:
[platformio]
[env] ;Common is done for all environments
monitor_flags= --raw
lib_extra_dirs =
  ./shared-config
  bblanchon/ArduinoJson @ ^6.17.2
  adafruit/Adafruit ADS1X15 @ ^1.1.1
  adafruit/Adafruit MCP4728 @ ^1.0.7
  adafruit/Adafruit NeoPixel @ ^1.7.0
  arduino-libraries/NTPClient @ ^3.1.0
test_build_project_src = true ;The test protocol will build the contents of the src folder when running tests. Allows us to test functions inside src
; ==== STATIC CHECKING ====
check_tool = cppcheck ; pvs-studio, cppcheck, clangtidy
check_flags =
 cppcheck: --enable=all
 cppcheck: --inline-suppr
 cppcheck: --suppress=*:.pio/*
[extra]
extra_scripts_default =
  shared/moveOutputBinaries.py
build_flags_default =
  -DDEBUG_ESP_PORT=Serial
  -DDEBUG_BUILD
  -DWEBSOCKET_DISABLED
  !python shared/GetCurrentDateTime.py
  !python shared/GetGitHash.py
;==========ESP32===========
[env:esp32]
build_type = debug
debug_tool = esp-prog
; monitor_filters = esp32_exception_decoder
  ${extra.build_flags_default}
extra_scripts = ${extra.extra_scripts_default}
I have also tried including check_flags = cppcheck: --suppress=*:.pio/* but that doesn’t work.
Is there something I’m doing wrong?
Anyone have any ideas for this?
Still can’t quite figure it out, it is a bit strange though since only some of the libraries from .pio are being included. Like the ADS1x15 package has so many problems with it but is not included in the output.
Maybe @valeros can help.
Hi @fr1 ! I guess the warnings are from header files? The reason you see that defects is because headers from that libraries are included somewhere in your main code. Cppecheck analyzes code on the level of translation units which means that headers and macros are expanded (including those from external libs). It seems that they should be suppressed according to your check flags, but I have some doubts about your syntax:
check_flags =
You’d better declare your flags in one line as in the docs Redirecting...
check_flags =
 cppcheck: --enable=all --inline-suppr --suppress=*:.pio/*
It looks like all on one line vs separate lines didn’t make a difference but I found the problem. I was referencing it relative to my project root: --suppress=*:.pio/* but changing it to --suppress=*:*/.pio/* has fixed it.
Thanks for your help, making it a one-liner has made .ini look a bit cleaner at least
I’ve also tried these flags (including many variations of):
  • cppcheck= -i.pio
  • check_src_filters= +<src/> -<.pio/>
  • cppcheck= --suppress=*:.pio/*
The suppress flag did decrease the total number of issues found within the .pio directories, but many still show up:
Component                                                     HIGH    MEDIUM    LOW
.pio/libdeps/espressif32/FastLED/src                           0        0       130
.pio/libdeps/espressif32/FastLED/src/fl                        1        0       34
.pio/libdeps/espressif32/FastLED/src/lib8tion                  0        0        3
.pio/libdeps/espressif32/FastLED/src/platforms/esp/32/rmt_4    0        0        3
src                                                            0        20       9
Is the continued inclusion of .pio/libdeps issues to be expected?
The closest I’ve come to my ideal lint results was by running CppCheck independently of PlatformIO:
cppcheck src/ --enable=all --suppress=missingIncludeSystem
This outputs the linting issues within src without including those from .pio. But… I’d really like to keep all my linting within the realm of pio check. Surely there must be a way to configure my platformio.ini to omit ANY linting issues from .pio, right?
