I’m having an issue where it appears PIO isn’t respecting the partition offset I set in menuconfig. When I turn on verbose logging while using ESP-IDF with Arduino as a component, PIO fails to upload with the error:
esptool write_flash: error: argument : Detected overlap at address: 0x8000 for file: /Documents/ESP/firmware/.pio/build/device-1/partitions.bin
If I reduce log level to info I don’t get this error, and am able to upload. This seems to track with the offset being at 0x8000 as mentioned here. However, I have set the partition offset to 0x10000 in menuconfig, and can see this reflected in the sdkconfig:
CONFIG_PARTITION_TABLE_OFFSET=0x10000
When I do reduce log level to info and upload, I get a boot loop that indicates that it’s not finding the partition table. I think it being overwritten, potentially due to this same issue:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:6584
load:0x40078000,len:15784
load:0x40080400,len:5136
entry 0x40080708
I (105) boot: Chip Revision: 3
I (121) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (74) boot: ESP-IDF 3.40001.200521 2nd stage bootloader
I (74) boot: compile time 17:18:41
I (75) boot: Enabling RNG early entropy source…
I (77) qio_mode: Enabling default flash chip QIO
I (82) boot: SPI Speed : 80MHz
I (85) boot: SPI Mode : QIO
I (88) boot: SPI Flash Size : 16MB
E (91) flash_parts: partition 0 invalid magic number 0x6e9
E (96) boot: Failed to verify partition table
E (100) boot: load partition table error!
My platformio.ini file:
[env]
board = esp-wrover-kit
framework = arduino, espidf
platform_packages =
framework-arduinoespressif32 @ GitHub - espressif/arduino-esp32: Arduino core for the ESP32
build_unflags =
-Os
-w
-O2
-DBOARD_HAS_PSRAM
-DESP32
-mfix-esp32-psram-cache-issue
-DCORE_DEBUG_LEVEL=3
board_build.f_flash = 80000000L
board_build.partitions = partitions.csv
board_build.flash_mode = qio
board_upload.flash_size = 16MB
board_upload.maximum_size = 16777216
My partitions.csv file:
#Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x11000, 0x4000,
otadata, data, ota, , 0x2000,
phy_init, data, phy, , 0x1000,
factory, app, factory, , 2M,
ota_0, app, ota_0, , 2M,
ota_1, app, ota_1, , 2M,
