PIO intents to install an installed library on `pio run`
Hello there,
I’ve an old issue which is not so critical but sometimes it’s annoying especially if I’d work offline.
That it tries to install an already installed library with its specied version.
I’ve this test platformio.ini:
[common]
	https://github.com/HamzaHajeir/H4#4.0.9
	https://github.com/HamzaHajeir/H4Tools#0.0.15
	https://github.com/HamzaHajeir/H4AsyncTCP#0.0.25
	https://github.com/HamzaHajeir/H4AsyncMQTT#1.0.0-rc12
	https://github.com/HamzaHajeir/ArmadilloHTTP#0.1.9
	https://github.com/HamzaHajeir/H4AsyncWebServer#0.0.11
	https://github.com/HamzaHajeir/h4plugins#3.5.5
[esp32]
	${common.lib_deps}
	AsyncUDP
	LittleFS
lib_ldf_mode = chain
	-DCORE_DEBUG_LEVEL=0
	-DEMBEDDED_PLATFORM
[env:esp32s3-devkitc]
extends = common, esp32
board = esp32-s3-devkitc-1
build_flags = ${esp32.build_flags}
	-DBOARD_HAS_PSRAM
board_build.flash_mode = qio
board_build.arduino.memory_type = qio_qspi
Where I specify all needed libraries in a project.
When I run: pio run, I get this line for seconds (freezing if I’m offline):
Library Manager: Installing H4AsyncWebServer @ >=0.0.11
And to make it closer, this is also mentioned in a library.properties file of another library that depends on it (Hense which might be a starting point). But strangely the issue only applies on this exact one.
More log of pio run:
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (2024.9.10) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
  • framework-arduinoespressif32 @ 3.0.5+sha.c3f26f0
  • tool-esptoolpy @ 4.7.6
  • tool-mklittlefs @ 3.2.0
  • tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
  • tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
  • toolchain-riscv32-esp @ 12.2.0+20230208
  • toolchain-xtensa-esp32s3 @ 12.2.0+20230208
    Library Manager: Installing AsyncUDP
    Warning! Could not find the package with ‘AsyncUDP’ requirements for your system ‘windows_amd64’
    Found 32 compatible libraries
    Scanning dependencies…
    |-- H4 @ 4.0.9+sha.6f2f510
    |-- H4Tools @ 0.0.15+sha.3c683d0
    |-- H4AsyncTCP @ 0.0.25+sha.231be9d
    |-- H4AsyncMQTT @ 1.0.0-rc12+sha.9d2b784
    |-- ArmadilloHTTP @ 0.1.9+sha.ac5bf86
    |-- H4AsyncWebServer @ 0.0.10+sha.8a78cbd
    |-- H4Plugins @ 3.5.5+sha.a01c966
    |-- LittleFS @ 3.0.5
Your repository tag 0.0.11 doesn’t match the version number in library.properties:
Consider also providing a library.json - See Creating Library — PlatformIO latest documentation
Remove AsyncUDP and LittleFS from your lib_deps!
These are built-in libraries.
Removing should also make this disappear:
Thanks for the answer and notes. Per LittleFS and AsyncUDP I remember I needed to add them backthen. I’ll try removing both while fixing the H4AsyncWebServer one.
UPDATE:
Your answer did solve the issue, given that I’ve already fixed the versioning, but didn’t reflect it to the environment.
Per library.json, I’ll consider doing that ofcourse.
