Error messages:
File "D:\msys64\mingw64\lib\python3.8\site-packages\platformio\__main__.py", line 102, in main
File "D:\msys64\mingw64\lib\python3.8\site-packages\click\core.py", line 764, in __call__
File "D:\msys64\mingw64\lib\python3.8\site-packages\click\core.py", line 717, in main
rv = self.invoke(ctx)
File "D:\msys64\mingw64\lib\python3.8\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "D:\msys64\mingw64\lib\python3.8\site-packages\click\core.py", line 1137, in invoke
File "D:\msys64\mingw64\lib\python3.8\site-packages\click\core.py", line 956, in invoke
File "D:\msys64\mingw64\lib\python3.8\site-packages\click\core.py", line 555, in invoke
return callback(*args, **kwargs)
File "D:\msys64\mingw64\lib\python3.8\site-packages\platformio\commands\home\command.py", line 52, in cli
from autobahn.twisted.resource import WebSocketResource
File "C:\Users\mafumafu\.platformio\packages\contrib-pysite\autobahn\twisted\__init__.py", line 58, in <module>
from autobahn.twisted.wamp import ApplicationSession
File "C:\Users\mafumafu\.platformio\packages\contrib-pysite\autobahn\twisted\wamp.py", line 50, in <module>
from autobahn.wamp import protocol, auth
File "C:\Users\mafumafu\.platformio\packages\contrib-pysite\autobahn\wamp\auth.py", line 43, in <module>
from cryptography.hazmat.primitives.kdf.pbkdf2 import PBKDF2HMAC
File "C:\Users\mafumafu\.platformio\packages\contrib-pysite\cryptography\hazmat\primitives\kdf\pbkdf2.py", line 12, in <module>
from cryptography.hazmat.primitives import constant_time
File "C:\Users\mafumafu\.platformio\packages\contrib-pysite\cryptography\hazmat\primitives\constant_time.py", line 11, in <module>
from cryptography.hazmat.bindings._constant_time import lib
ModuleNotFoundError: No module named 'cryptography.hazmat.bindings._constant_time'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
Operation system: Windows 10
Python intepreter: 3.8.0 [GCC 9.2.0 64 bit (AMD64)] on win 32
I promise the version of platformio is latest!
Proved by pip:
λ pip install platformio -U
Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
Requirement already up-to-date: platformio in d:\msys64\mingw64\lib\python3.8\site-packages (4.1.0)
Requirement already satisfied, skipping upgrade: colorama in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (0.4.1)
Requirement already satisfied, skipping upgrade: semantic-version<3,>=2.8.1 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (2.8.2)
Requirement already satisfied, skipping upgrade: bottle<0.13 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (0.12.17)
Requirement already satisfied, skipping upgrade: requests<3,>=2.4.0 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (2.22.0)
Requirement already satisfied, skipping upgrade: pyserial!=3.3,<4,>=3 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (3.4)
Requirement already satisfied, skipping upgrade: marshmallow<3,>=2.20.5 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (2.20.5)
Requirement already satisfied, skipping upgrade: click<8,>=5 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (7.0)
Requirement already satisfied, skipping upgrade: tabulate<1,>=0.8.3 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (0.8.5)
Requirement already satisfied, skipping upgrade: pyelftools<1,>=0.25 in d:\msys64\mingw64\lib\python3.8\site-packages (from platformio) (0.25)
Requirement already satisfied, skipping upgrade: chardet<3.1.0,>=3.0.2 in d:\msys64\mingw64\lib\python3.8\site-packages (from requests<3,>=2.4.0->platformio) (3.0.4)
Requirement already satisfied, skipping upgrade: idna<2.9,>=2.5 in d:\msys64\mingw64\lib\python3.8\site-packages (from requests<3,>=2.4.0->platformio) (2.8)
Requirement already satisfied, skipping upgrade: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in d:\msys64\mingw64\lib\python3.8\site-packages (from requests<3,>=2.4.0->platformio) (1.25.6)
Requirement already satisfied, skipping upgrade: certifi>=2017.4.17 in d:\msys64\mingw64\lib\python3.8\site-packages (from requests<3,>=2.4.0->platformio) (2019.9.11)
Proved by pio update
λ pio upgrade
You're up-to-date!
PlatformIO 4.1.0 is currently the newest version available.
It seems like the absence of cryptography
, but there’s no use after I install it via pip.
λ pip install cryptography
Requirement already satisfied: cryptography in d:\msys64\mingw64\lib\python3.8\site-packages (2.8)
Requirement already satisfied: six>=1.4.1 in d:\msys64\mingw64\lib\python3.8\site-packages (from cryptography) (1.13.0)
Requirement already satisfied: cffi!=1.11.3,>=1.8 in d:\msys64\mingw64\lib\python3.8\site-packages (from cryptography) (1.13.2)
Requirement already satisfied: pycparser in d:\msys64\mingw64\lib\python3.8\site-packages (from cffi!=1.11.3,>=1.8->cryptography) (2.19)
