I (somehow) managed to get PIO debugging to work on a simple program, I can set breakpoints, step etc, and even hover over a variable to see its current value - but - I can’t find a way to have the debugger populate the variables window (and show the values). I do get an error during PIO initialising remote target (part of debug console output showing error)
========================= [SUCCESS] Took 5.58 seconds =========================
Reading symbols from c:\Users\SteveV\Documents\PlatformIO\Projects\Next1.pio\build\nanoatmega328new\firmware.elf…
done.
PlatformIO: debug_tool = avr-stub
__udivmodsi4 () at …/…/…/…/gcc/libgcc/config/avr/lib1funcs.S:1648
1648 …/…/…/…/gcc/libgcc/config/avr/lib1funcs.S: No such file or directory.
PlatformIO: Resume the execution to debug_init_break = tbreak main
PlatformIO: More configuration options → Redirecting...
Is the missing file the reason why the variables are not shown?
If yes, where should it be and how should it be included??
Also, I get an ‘task error’ as follows:
Error: The PlatformIO task detection didn’t contribute a task for the following configuration:
“type”: “PlatformIO”,
“task”: “Build (nanoatmega328)”,
“problemMatcher”: [
“$platformio”
“group”: “build”,
“label”: “PlatformIO: Build (nanoatmega328)”
The task will be ignored.
“problemMatcher”: [
“$platformio”
“group”: “build”,
Is this a problem? how do I fix or make it go away?
I Hope you can assist (an extremely inexperienced person with the modern tools - I last did embedded programming a little over 30 years ago!!)
Cheers
