Pio check fails, when running verbose, checks are passed
greetings
I have a problem with pio check. When running with the default env I get the error:
❯ platformio check
Checking d1_mini > cppcheck (board: d1_mini; platform: espressif8266@2.4.0; framework: arduino)
Error: cppcheck failed to perform check! Please examine tool output in verbose mode.
========================================================================================== [FAILED] Took 8.10 seconds ==========================================================================================
Environment      Tool      Status    Duration
d1_mini          cppcheck  FAILED    00:00:08.098
nodemcuv2        cppcheck  IGNORED
local_unittests  cppcheck  IGNORED
==================================================================================== 1 failed, 0 succeeded in 00:00:08.098 ====================================================================================
When running with verbose as requested I get:
platformio check -v
11/11 files checked 100% done
No defects found
========================================================================================== [PASSED] Took 8.05 seconds ==========================================================================================
d1_mini          cppcheck  PASSED    00:00:08.053
========================================================================================= 1 succeeded in 00:00:08.053 =========================================================================================
Any idea whats wrong here and howto fix/debug that?
Can you upload the project for which this is reproducable? You can do a bug report to GitHub - platformio/platformio-core: A professional collaborative platform for embedded development then.
of course: the project can be found here:
could u reproduce this. just to be sure, no layer8 problem is involved :wink:
