when compiling WLED I get the following error:
Retrieved `.pio\build\d1_minix\FrameworkArduino\umm_malloc\umm_integrity.c.o' from cache
Retrieved `.pio\build\d1_minix\FrameworkArduino\umm_malloc\umm_local.c.o' from cache
Retrieved `.pio\build\d1_minix\FrameworkArduino\umm_malloc\umm_malloc.cpp.o' from cache
Retrieved `.pio\build\d1_minix\FrameworkArduino\umm_malloc\umm_poison.c.o' from cache
Retrieved `.pio\build\d1_minix\FrameworkArduino\wpa2_eap_patch.cpp.o' from cache
Retrieved `.pio\build\d1_minix\libFrameworkArduino.a' from cache
Linking .pio\build\d1_minix\firmware.elf
.pio\build\d1_minix\src\dmx.cpp.o: file not recognized: file format not recognized
*** [.pio\build\d1_minix\firmware.elf] Error 1
========================================================================================= [FAILED] Took 17.17 seconds =========================================================================================
Environment Status Duration
d1_minix FAILED 00:00:17.174
==================================================================================== 1 failed, 0 succeeded in 00:00:17.174 ====================================================================================
This happens since the system crashed, I tried to delete the cache folders:
But somehow it still happens and I don’t know hoe to force a compete redo. Deleting the build folder also does not help.
Any Idea what I can try else?
