kadmin
February 28, 2019, 12:56pm
#1
Before the update I used the following code to make remap:
afio_remap(AFIO_REMAP_USART1);
afio_cfg_debug_ports (AFIO_DEBUG_SW_ONLY);
afio_remap (AFIO_REMAP_SPI1);
gpio_set_mode (GPIOB, 3, GPIO_AF_OUTPUT_PP);
gpio_set_mode (GPIOB, 4, GPIO_INPUT_FLOATING);
gpio_set_mode (GPIOB, 5, GPIO_AF_OUTPUT_PP);
Now this code doesn’t work anymore, how can I make it work? Libmaple inclusions also do not work((
kadmin
February 28, 2019, 1:56pm
#3
I made a change to platformio.ini file:
I made a correction according to the instructions:
.bss :
. = ALIGN(8);
__bss_start__ = .;
*(.bss .bss.* .gnu.linkonce.b.*)
*(COMMON)
. = ALIGN (8);
__bss_end__ = .;
_end = __bss_end__;
end = _end;
} > REGION_BSS
But unfortunately it didn’t help, enabling libmaple is still not available(( I use QtCreator as IDE and fixed paths:
INCLUDEPATH += $${HOMEDIR}/.platformio/packages/framework-arduinoststm32-maple/STM32F1/cores/maple
INCLUDEPATH += $${HOMEDIR}/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple
INCLUDEPATH += $${HOMEDIR}/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include/libmaple
INCLUDEPATH += $${HOMEDIR}/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/stm32f1/include
But I still can’t connect libmaple
#include <libmaple/adc.h>
#include <libmaple/iwdg.h>
#include <libmaple/gpio.h>
Try adding board_build.variant=custom
to your build environment in platformio.ini
file.
This is not the result I’m getting:
main.cpp
void setup()
void loop()
and platformio.ini
[env:bp_debug]
platform = https://github.com/platformio/platform-ststm32.git
board = genericSTM32F103C8
debug_tool = stlink
upload_protocol = stlink
Results in
arm-none-eabi-g++ -o .pioenvs\bp_debug\firmware.elf -T jtag_c8.ld -Os -mthumb -mcpu=cortex-m3 -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols .pioenvs\bp_debug\src\main.cpp.o -LC:\Users\Maxi\.platformio\platforms\ststm32\ldscripts -L.pioenvs\bp_debug -LC:\Users\Maxi\.platformio\packages\framework-arduinoststm32-maple\STM32F1\variants\generic_stm32f103c\ld -Wl,--start-group .pioenvs\bp_debug\libFrameworkArduinoVariant.a .pioenvs\bp_debug\libFrameworkArduino.a -lm -lgcc -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pioenvs\bp_debug\firmware.elf"])
arm-none-eabi-objcopy -O binary .pioenvs\bp_debug\firmware.elf .pioenvs\bp_debug\firmware.bin
DATA: [== ] 15.3% (used 3136 bytes from 20480 bytes)
PROGRAM: [== ] 22.8% (used 14952 bytes from 65536 bytes)
[SUCCESS] Took 4.61 seconds
Please show the full compiler error.
kadmin
February 28, 2019, 2:18pm
#6
Thank you very much for your answers! Yes, I just tried to re-build the project with your settings and it worked. The only thing I did not build QtCreator, but in Visual Studio code. My assumption is that the paths are incorrectly specified in QtCreator after executing the command: platformio init – IDE qtcreator --board genericSTM32F103CB
Oh then my example is kinda wrong, I’m using
So please double check that. But it still compiles for me when I change the board target.
kadmin
February 28, 2019, 2:23pm
#8
Yes the project builds successfully, thank you very much!!! Is it possible to see the paths of the libraries used in Visual Studio Code so that you can manually add them to QtCreator?
After initializing the project with --ide=vscode
, the file .vscode\c_cpp_properties.json
contains your wanted paths. Although they should really be already there. Maybe try to re-init the project? Just pio init --ide=qtcreator
again.
kadmin
February 28, 2019, 2:33pm
#10
No doubt you are my hero! Simple reinitialization of the project solved all the problems in QtCreator, I do not understand why I did not do it before(( thanks again!
