I have an example Code for Arduino Mega, which has the Atmega2560 as Controller onboard. In platformio.ini I have Setup for Board pro16Mhzatmega168, which is for the Arduino ProMini Board Variant I would like to use.
Per accident i forgot to replace the Pin Numbers in my Header File to that of my Arduino Board. The issue is, that I can compile the Code without any Errors or warnings, although the pins I access via pinMode do not exist at all for my Arduino Board!
Example “pinMode(53, OUTPUT);”
Digital Pin 53 is the CS Pin of SPI for Arduino Mega, but does not exist at all for Arduino ProMini or UNO. How can this work? To be honest I don’t like the Arduino way of Pin re-mapping at all, so i will replace the Arduino functions with direct Port Access. However I would like to understand, how this is working.
The way the Arduino API and the Wiring framework it’s based on are designed, they cannot check at compile-time if the specified pin number is correct.
Even at run-time, operations with invalid pin numbers are simply ignored.
Whether it has become successful due to or despite this design, I leave up to you…
OK, thanks. However pinMode() and digitalWrite() shall use valid numbers because the functions are more or less wrappers to write DDRx and PORTx registers respectively. So e.g If I try to access digital pin 53 with above mentioned Arduino functions for a Board, which ends with Pin 19 how is it mapped? If it is ignored, as you wrote, does it mean that the complete Pin access is rejected? In this case I would expect at least a warning, or did I miss something? I think the whole behaviour is an Arduino issue and not platformio related. Regards Andreas
Where do you expect the warning to appear during run-time? There is no standard error or logging channel. It’s a small and restricted device after all.
All operations with invalid pins will not do anything (except spend a few CPU cycles). See for example the source code of pinMode
of the AVR Arduino core: ArduinoCore-avr/wiring_digital.c at master · arduino/ArduinoCore-avr · GitHub
If the pin is invalid, it returns on line 35.
And the same check is repeated in each function every time it’s called.
OK, thanks for explanation and the provided Link. I am more familiar with the pure AVR C programming rather than the Arduino C++ style…
Regards Andreas
