Hi guys,
I have a problem and I would ask you for help.
I have the following scenario:
I built a small software for Mega2560 compatible board.
Now, I want to switch to a Due compatible board.
In order to use the DMA of the Due I have to switch also the display library. The display controller is not the same.
I though using the PIMPL idiom would be good to “hide” the actual hardware dependent implementation.
I created first the wrapper UI.h
#ifndef UI_H
#define UI_H
#include <SPI.h>
#define TFT_RST 10
#define TFT_DC 7
#define TFT_CS 9
class UI
public:
UI();
~UI();
void begin();
void reset();
void drawSth();
private:
struct Impl;
Impl* _impl;
Then, I have the UI.cpp file:
#include “UI.h”
#if Is_Atmel
#include "UI_ILI9341.cpp"
#else
#include "UI_ILI9325.cpp"
At this point, I want to change the implementation based on a build_flag defined in the environments of the platformio.ini
And last but not least the real implementation for the hardware:
#ifndef UI_ILI9341_H
#define UI_ILI9341_H
#include "UI.h"
#include "ILI9341_due_config.h"
#include "ILI9341_due.h"
#include "allFonts.h"
#include "allIcons.h"
struct UI::Impl
ILI9341_due tft = ILI9341_due(TFT_CS, TFT_DC, TFT_RST);
void begin()
tft.begin();
tft.setRotation(iliRotation90);
reset();
void reset()
tft.fillScreen(ILI9341_WHITE);
void drawSth()
tft.fillRectangle(0, 0, 20, 20, ILI9341_BLACK);
UI::UI()
_impl = new Impl();
UI::~UI()
delete _impl;
void UI::begin()
_impl->begin();
void UI::reset()
_impl->reset();
void UI::drawSth()
_impl->drawSth();
In addition, there is of course an implementation for the other display and the Atmega2560.
But for now, the implementation is completely empty. The public methods are available, but empty.
When I am trying to compile the whole thing for the Atmega2560 I am getting the following error:
In file included from C:\Users\phoef.platformio\packages\framework-arduinoavr\cores\arduino/Arduino.h:28:0,
from C:\Users\phoef.platformio\packages\framework-arduinoavr\libraries_cores_\arduino\SPI\src/SPI.h:17,
from lib\UI\UI.h:4,
from lib\UI\UI_ILI9341.cpp:4:
lib\Fonts/ArialRounded34.h:48:33: error: variable ‘ArialRounded34’ must be const in order to be put into read-only section by means of 'attribute((progmem))'
static uint8_t ArialRounded34[] PROGMEM = {
lib\Fonts/Arial29.h:48:26: error: variable ‘Arial29’ must be const in order to be put into read-only section by means of 'attribute((progmem))'
static uint8_t Arial29[] PROGMEM = {
*** [.pioenvs\megaatmega2560\libf9d\UI\UI_ILI9341.o] Error 1
I was hoping, that the LDF would ignore the not included file.
I guess it is not, because I am including the cpp file?
Any ideas how to achieve a hardware independent interface based on environments?
Thanks
