Hello there,
I am currently developing on the SAME51 and need to turn down the MCU frequency to 100 MHz or less. I previsouly managed to tune it up to 120 MHz but my program fails when trying to do so.
First of all I was developing on VSC with platformio and realised that the program is stopping at:
while (0 == OSCCTRL->Dpll[0].DPLLSTATUS.bit.CLKRDY || 0 == OSCCTRL->Dpll[0].DPLLSTATUS.bit.LOCK); //wait for the DPLLSTATUS.bit.CLKRDY = ReadyBit= 1 and LOCKbit = 1;
and is never able to leave that.
I then pasted exakt the same code into my Microchipstudio test project to use their debugger for better clearance and realised that my code works there. Upon further investigations I saw that commands like OSCCTRL->Dpll[0].DPLLCTRLA.bit.ENABLE = 0; don’t do anything in my Peripherals view. Also closing it and reopening does nothing to the values. It also seems like values that are initialized on MCU startup are also completly ignored by this view. Now my problem is that I don’t know why the exact same code is doing different things in the 2 different IDEs and if the issue is code related or IDE related…
Below i pasted my full code
#define CLOCK100
#define GCLK0 0
#define GCLK1 1
#define GCLK2 2
#define GCLK3 3
#define GCLK4 4
#define GCLK5 5
#define GCLK6 6
//testing
#ifdef CLOCK100 // for higher temperature for up to 125°C
#define F_CPU 11000000
#define LDR_var (((unsigned long)F_CPU * 32) / 32768)
void clock_init()
NVMCTRL->CTRLA.bit.AUTOWS = 1;
GCLK->CTRLA.bit.SWRST = 1;
while (GCLK->CTRLA.bit.SWRST);
//switch on the extern 32,768 KHz Quarz
OSC32KCTRL->XOSC32K.reg = OSC32KCTRL_XOSC32K_ENABLE |
OSC32KCTRL_XOSC32K_XTALEN |
OSC32KCTRL_XOSC32K_EN32K |
OSC32KCTRL_XOSC32K_RUNSTDBY |
OSC32KCTRL_XOSC32K_STARTUP(7);
while (0 == OSC32KCTRL->STATUS.bit.XOSC32KRDY);
//XOSC32K -> GCLK2
PORT->Group[PORTA].PINCFG[16].reg = PORT_PINCFG_PMUXEN| PORT_PINCFG_DRVSTR; // Enable peripheral multiplexer
PORT->Group[PORTA].PMUX[16/2].reg = 12; // Set peripheral function F (TCC0/WO[2])
GCLK->GENCTRL[GCLK2].reg = GCLK_GENCTRL_SRC(GCLK_SOURCE_XOSC32K) | GCLK_GENCTRL_RUNSTDBY | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_OE;
/* disable the DPLL before changing the configuration */
while (OSCCTRL->Dpll[0].DPLLSYNCBUSY.reg) {}
//XOSC32K -> GCLK2 -> FDPLL0
GCLK->PCHCTRL[OSCCTRL_GCLK_ID_FDPLL0].reg = GCLK_PCHCTRL_GEN_GCLK2 | GCLK_PCHCTRL_CHEN;
while (0 == (GCLK->PCHCTRL[OSCCTRL_GCLK_ID_FDPLL0].reg & GCLK_PCHCTRL_CHEN));
OSCCTRL->Dpll[0].DPLLRATIO.reg = OSCCTRL_DPLLRATIO_LDRFRAC(LDR_var % 32) | OSCCTRL_DPLLRATIO_LDR((LDR_var / 32) - 1);
OSCCTRL->Dpll[0].DPLLCTRLB.reg = OSCCTRL_DPLLCTRLB_REFCLK_XOSC32 |
OSCCTRL_DPLLCTRLB_DIV(1) |
OSCCTRL_DPLLCTRLB_WUF |
OSCCTRL_DPLLCTRLB_LBYPASS;
//FDPLL0 enable
OSCCTRL->Dpll[0].DPLLCTRLA.reg = OSCCTRL_DPLLCTRLA_ENABLE | OSCCTRL_DPLLCTRLA_RUNSTDBY;
//REG_OSCCTRL_DPLLCTRLB0 = 0;
//REG_OSCCTRL_DPLLCTRLB0 = OSCCTRL_DPLLCTRLB_LBYPASS | OSCCTRL_DPLLCTRLB_REFCLK(0); // errata says to bypass lock when using internal 32k oscillator as source
OSCCTRL->Dpll[0].DPLLCTRLA.bit.ENABLE = 1;
//FDPLL0 (120MHz) --> CPU
PORT->Group[PORTB].PINCFG[14].reg = PORT_PINCFG_PMUXEN| PORT_PINCFG_DRVSTR; // Enable peripheral multiplexer
PORT->Group[PORTB].PMUX[14/2].reg = 12; // Set peripheral function F (TCC0/WO[2])
GCLK->GENCTRL[GCLK0].reg = GCLK_GENCTRL_SRC(GCLK_SOURCE_DPLL0) | GCLK_GENCTRL_RUNSTDBY | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_OE;
while ((GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL_GCLK0) == GCLK_SYNCBUSY_GENCTRL_GCLK0);
OSCCTRL->DFLLCTRLA.reg = 0;
OSCCTRL->DFLLMUL.reg = OSCCTRL_DFLLMUL_CSTEP(0x1) |
OSCCTRL_DFLLMUL_FSTEP(0x1) |
OSCCTRL_DFLLMUL_MUL(0xBB80);
while (OSCCTRL->DFLLSYNC.bit.DFLLMUL);
OSCCTRL->DFLLCTRLB.reg = 0;
while (OSCCTRL->DFLLSYNC.bit.DFLLCTRLB);
OSCCTRL->DFLLCTRLA.bit.ENABLE = 1;
while (OSCCTRL->DFLLSYNC.bit.ENABLE);
OSCCTRL->DFLLVAL.reg = OSCCTRL->DFLLVAL.reg;
while (OSCCTRL->DFLLSYNC.bit.DFLLVAL);
OSCCTRL->DFLLCTRLB.reg = OSCCTRL_DFLLCTRLB_WAITLOCK |
OSCCTRL_DFLLCTRLB_CCDIS |
OSCCTRL_DFLLCTRLB_USBCRM;
while (!OSCCTRL->STATUS.bit.DFLLRDY);
//Switch Generic Clock Generator 5 to DFLL48M. for SERCOM5 48 MHz
GCLK->GENCTRL[GCLK5].reg = GCLK_GENCTRL_SRC(GCLK_GENCTRL_SRC_DFLL) |
GCLK_GENCTRL_IDC |
GCLK_GENCTRL_OE |
GCLK_GENCTRL_GENEN;
while (GCLK->SYNCBUSY.bit.GENCTRL5);
//Switch Generic Clock Generator 6 to 120MHz. for observation purposeses
GCLK->GENCTRL[GCLK6].reg = GCLK_GENCTRL_SRC(GCLK_SOURCE_DPLL0) |
GCLK_GENCTRL_IDC |
GCLK_GENCTRL_OE |
GCLK_GENCTRL_GENEN;
while (GCLK->SYNCBUSY.bit.GENCTRL6);
//GCLK5 -> SERCOM5 48 MHz
GCLK->PCHCTRL[SERCOM5_GCLK_ID_CORE].reg = GCLK_PCHCTRL_GEN_GCLK5 | GCLK_PCHCTRL_CHEN;
while ((GCLK->PCHCTRL[SERCOM5_GCLK_ID_CORE].reg & GCLK_PCHCTRL_CHEN) != GCLK_PCHCTRL_CHEN);
//FDPLL0 -> GCLK1 -> GCLK6 -> Pb12 -> LED Alive 120MHz
// !!! with Bit12 = 1 !!!
GCLK->GENCTRL[GCLK1].reg =
GCLK_GENCTRL_DIV(120) | GCLK_GENCTRL_SRC(GCLK_GENCTRL_SRC_DPLL0) | GCLK_GENCTRL_DIVSEL | GCLK_GENCTRL_GENEN;
// 120 : 120 = 1 MHz with GCLK_GENCTRL_DIVSEL 100KHz ^------------------------------0x07 (Manual page 166)
while ((GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL_GCLK1) == GCLK_SYNCBUSY_GENCTRL_GCLK1) {
//wait for the GCLK1 Generator 1 synchronization
// !!! with Bit12 = 1 !!! v---PB12 Pin25
GCLK_GENCTRL_DIV(100) | GCLK_GENCTRL_SRC(GCLK_SOURCE_GCLKGEN1) | GCLK_GENCTRL_DIVSEL | GCLK_GENCTRL_OE |
GCLK_GENCTRL_GENEN;
// 1MHz : 100 = 10 kHz with GCLK_GENCTRL_DIVSEL 1,8Hz 0,56 ms Periode ^------------------------------0x03 (Manual page 166)
while ((GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL_GCLK6) == GCLK_SYNCBUSY_GENCTRL_GCLK6) {
//wait for the GCLK1 Generator 6 synchronization
//FDPLL0 -> GCLK4
GCLK->GENCTRL[GCLK4].reg = GCLK_GENCTRL_DIV(2) | GCLK_GENCTRL_SRC(GCLK_SOURCE_DPLL0) | GCLK_GENCTRL_GENEN;
// 120Mhz : 2 = 60MHz ^---------------------------------------------0x07 DPLL0 DPLL0 output (Manual Seite 166)
// 120Mhz : 5 = 24MHz
// 120Mhz : 15 = 8MHz
while((GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL_GCLK4) == GCLK_SYNCBUSY_GENCTRL_GCLK4)
// wait for GCLK4 synchronization
I also tried editing the register manually by rightclick on the register in the peripherals view and choose “update value” i then could write a custom value to the register, but also this does nothing to the values at all.
Let me know if you need any furhter informations on this.
