Hello Community,
I’m discovering PlatformIO for some serious development and I’m trying to build an application for a Teensy++ 2.0 device, something like a keyboard macro handler.
I’ve installed Platform as an Extension of VisualStudioCode (v1.45, AMD64, Linux Arch) and I’ve some troubles with a global teensy variable that cannot be found inside the PlatformIO project. To summarize and focus on the point here’s my platform.ini:
[env:teensy]
platform = teensy
board = teensy2pp
and to simplify my code here’s something that doesn’t work in my main.cpp file:
#include "usb_private.h"
extern volatile uint8_t keyboard_leds;
Serial.begin(9600);
Serial.println(keyboard_leds);
Serial.println("Loop");
I need an external variable named keyboard_leds
that contains current keyboard’s led status, this seems to be something I can use in each Teensy board, I’ve googled around for a while and I’ve seen folks on stackoverflow adding #include "usb_private.h"
to solve the problem with PlatformIO. This code in my Arduino IDE works (test.ino):
Serial.begin(9600);
So I was basically trying to reproduce the same with PlatformIO. Using the #include
statement doesn’t seems to be effective at all, I’m getting the same compilation error with or without it.
here’s the error:
> Executing task: platformio run <
Processing teensy (platform: teensy; board: teensy2pp; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy2pp.html
PLATFORM: Teensy 4.8.0 > Teensy++ 2.0
HARDWARE: AT90USB1286 16MHz, 8KB RAM, 127KB Flash
- framework-arduinoteensy 1.151.0 (1.51)
Found 96 compatible libraries
Linking .pio/build/teensy/firmware.elf
.pio/build/teensy/src/main.cpp.o: In function `setup':
main.cpp:(.text.setup+0x10): undefined reference to `keyboard_leds'
*** [.pio/build/teensy/firmware.elf] Error 1
======================================================================== [FAILED] Took 0.53 seconds ========================================================================
Is it something related to paths or some sort of PlatformIO misconfiguration (or missing setup) on my side ?
Do you need additional information about it ?
Thank you in advance for your reply
Ben
