Hi!
I have a working dev environment, i wanted to add a release environment.
Flashing to the device a new app version (with ota) i get an MD5 error with the partition table.
prompting me to look into sdkconfig for both envs.
pio.ini
[env]
board = esp-wrover-kit
framework = espidf
board_build.partitions = partition_table.csv
-D CONFIG_SPIRAM_CACHE_WORKAROUND
-D SOFTWARE_VERSION=10
-D HARDWARE_VERSION=3
upload_port = /dev/ttyUSB*
monitor_port = /dev/ttyUSB*
[env:selectionDev]
build_type = debug
${env.build_flags}
-D DEV_MODE
[env:selectionProd]
build_type = release
${env.build_flags}
Working Dev sdk (only partition area):
# Partition Table
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions_table.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_table.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x9000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
auto generated config for release:
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=y
# CONFIG_PARTITION_TABLE_CUSTOM is not set
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_singleapp.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
The problem is obvious, the release does not have the partition table or the correct offset in it. Why though?
