我在使用VScode中的Paltform IO 对stm32 F103ZET6开发板进行编程时,串口无法使用.TT L芯片用的是PL2303.接到了STM32的PA9和PA10上,接线和TTL芯片问题,使用Keil V5编写的软件测试过(可以用).
我的Paltform IO 代码:
pinMode(PA2,OUTPUT);
digitalWrite(PA2,LOW);
delay(2000);
Serial.print("Test!");
digitalWrite(PA2,HIGH);
delay(2000);
然后platformio.ini是这样的:
[env:genericSTM32F103ZE]
platform = ststm32
board = genericSTM32F103ZE
; change microcontroller
board_build.mcu = stm32f103zet6
; change MCU frequency
board_build.f_cpu = 72000000L
upload_protocol = jlink
debug_tool = jlink
望各位大神,提示一下出错的地方!万分感激
Translation by DeepL
When I program the stm32 F103ZET6 development board using the Paltform IO in VScode, the serial port is not working. The TTL chip is PL2303. It is connected to PA9 and PA10 of STM32, wiring and TTL chip problem, tested with software written in Keil V5 (it works).
My PaltformIO code:
Then platformio.ini looks like this:
I hope you guys can give me a hint about what’s wrong! Thank you very much!
