Could someone provide TeamViewer access to debug this issue?
Hallo Ivan,
I could provide a TeamViewer session tomorrow, if that’s ok for you?
Just drop me a PM, when you’re ready to go.
I’m having similar issues here as well on Windows 10 and VS Code. No anti-virus installed just Windows defender (disabling Windows defender doesn’t help) I’ve also tried on 2 different machines with the same result;
> Executing task: platformio.exe run --target upload <
[12/05/17 10:24:37] Processing mzeropro (platform: atmelsam; board: mzeropro; framework: arduino)
PackageManager: Installing tool-openocd @ ~1.900.2
Downloading [#-----------------------------------] 4%
Please manually remove file `C:\Users\dale\.platformio\packages\_tmp_installing-5ht39b-package\tool-openocd-windows-1.900.2.tar.gz`
Warning! Package Mirror: [Error 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\dale\\.platformio\\packages\\_tmp_installing-5ht39b-package\\tool-openocd-windows-1.900.2.tar.gz'
Looking for other mirror...
Downloading [------------------------------------] 2%
Please manually remove file `C:\Users\dale\.platformio\packages\_tmp_installing-guu8jj-package\tool-openocd-windows-1.900.2.tar.gz`
Warning! Package Mirror: [Error 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\dale\\.platformio\\packages\\_tmp_installing-guu8jj-package\\tool-openocd-windows-1.900.2.tar.gz'
Error: Could not install 'tool-openocd' with version requirements '~1.900.2' for your system 'windows_amd64'.
If you use Antivirus, it can block PlatformIO Package Manager. Try to disable it for a while.
Same issue on windows 10 when installing tools for intel_arc32…manully download and extract works.
if you donot know how to find the download url, check out here :https://dl.bintray.com/platformio/dl-packages/manifest.json,
and you can find the list of tools in the platform.json located in YOUR_INSTALL_PATH\.platformio\platforms\your board\
I’m having similar issues above. I try to install tool-avrdude individual in Windows PowerShell with this command: platformio platform install https://github.com/platformio/platform-atmelavr.git --with-package=tool-avrdude. So, surprise ! It’s work !
Yep! This worked for me! I manually extracted avrdude (in my case) and the rest of my issues went away. Thank you!!
This is a known issue, see temporary solution
UPDATE MARCH 1
I tried again the quick solution and it works:
- Add PATH variable in Windows with C:\Users{user name}.platformio\penv\Scripts
- Open Windows power shell
- Run pio run --target upload
- The packages is downloaded
- Upload now works in PIO IDE
It really works well! Thank you.
I have the same issue
Processing genericSTM32F103C8 (platform: ststm32; board: genericSTM32F103C8; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing platformio/framework-arduinoststm32 @ ~4.20100.0
Unpacking [###################################-] 97% 00:00:01
Unpacking...
