Hi all,
How to use in ESP32 this library,
I used it in Arduino IDE and it was wonderfully, but wuth platform io something not correctly,
How can help me please?
With this little desciption, no code, no platformio.ini
, no logs, it’s impossible to say anything. On the most basic level, if you use the same Arduino core version, library version, same project code and same board settings as you did in the Arduino IDE, it should work the same.
