OTA update using sim800 with esp32
I need to update the code using the sim800l and esp32
but when tried to read file using TinyGSM lib i can’t print all data from them .
#include "GSM_OTA.hpp"
#include <Update.h>
#define FILE_URL  "https://shehabhassan.github.io/FOTA_TEST/firmware.bin"
const char* firmware_url = FILE_URL;
static const char *url = FILE_URL;
#define TINY_GSM_MODEM_SIM800
#define SerialMon Serial
#define SerialAT Serial2
#if !defined(TINY_GSM_RX_BUFFER)
#define TINY_GSM_RX_BUFFER 2048
#define TINY_GSM_DEBUG SerialMon
#define GSM_AUTOBAUD_MIN 9600
#define GSM_AUTOBAUD_MAX 115200
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
#define GSM_PIN ""
const char apn[] = "YourAPN";  // Replace with your correct APN
const char gprsUser[] = "";    // Replace with your username if required
const char gprsPass[] = "";    // Replace with your password if required
const char server[] = "https://shehabhassan.github.io";
const char resource[] = "/FOTA_TEST/firmware.bin";
const int port = 443;
uint32_t knownFileSize = 928416;//
#include <TinyGsmClient.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
TinyGsmClient client(modem);
void printDeviceInfo(){
  Serial.println();
  Serial.println("--------------------------");
  Serial.println(String("Build:    ") +  __DATE__ " " __TIME__);
  Serial.println(String("Flash:    ") + ESP.getFlashChipSize() / 1024 + "K");
  Serial.println(String("ESP sdk:  ") + ESP.getSdkVersion());
  Serial.println(String("Chip rev: ") + ESP.getChipRevision());
  Serial.println(String("Free mem: ") + ESP.getFreeHeap());
  SerialMon.begin(115200);
  delay(10);
  SerialMon.println("Wait...");
  if (!SPIFFS.begin(true)) {
    SerialMon.println("An Error has occurred while mounting SPIFFS");
    return;
  TinyGsmAutoBaud(SerialAT, GSM_AUTOBAUD_MIN, GSM_AUTOBAUD_MAX);
  delay(6000);
  SerialMon.println("Initializing modem...");
  modem.restart();
  modem.init();
  String modemInfo = modem.getModemInfo();
  SerialMon.print("Modem Info: ");
  SerialMon.println(modemInfo);
  SerialMon.println(HEAP_AVAILABLE());
  printDeviceInfo();
#if TINY_GSM_USE_GPRS
  if (GSM_PIN && modem.getSimStatus() != 3) { modem.simUnlock(GSM_PIN); }
  NetworkConnect();
  Tiny_GPRS_CONNECT();
    // if you get a connection, report back via serial:
    if (!client.connect(server, port))
        Serial.println(" fail");
        delay(10000);
        return;
    Serial.println(" OK");
    // Make a HTTP request:
    client.print(String("GET ") + resource + " HTTP/1.0\r\n");
    client.print(String("Host: ") + server + "\r\n");
    client.print("Connection: close\r\n\r\n");
    long timeout = millis();
    while (client.available() == 0)
        if (millis() - timeout > 5000L)
            Serial.println(">>> Client Timeout !");
            client.stop();
            delay(10000L);
            return;
    Serial.println("Reading header");
    uint32_t contentLength = knownFileSize;
    File file = SPIFFS.open("/update.bin", FILE_APPEND);
  long timeout1 = millis();
  uint32_t response = 0;
     while (client.available()) {
    String line = client.readStringUntil('\n');
    line.trim();
    SerialMon.println(line);    // Uncomment this to show response headers
  modem.gprsDisconnect();
  SerialMon.println(F("GPRS disconnected"));
  while (true) { delay(1000); }
void NetworkConnect() {
  SerialMon.print("Waiting for network...");
  if (!modem.waitForNetwork()) {
    SerialMon.println(" fail");
    delay(10000);
    return;
  SerialMon.println(" success");
  if (modem.isNetworkConnected()) { SerialMon.println("Network connected"); }
void Tiny_GPRS_CONNECT() {
  SerialMon.print(F("Connecting to "));
  SerialMon.print(apn);
  if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
    delay(10000);
    return;
  if (modem.isGprsConnected()) { SerialMon.println("GPRS connected"); }
