I’m using a Wemos D1 mini ESP32 board for a new project. Over USB it is possible to upload the code but not via OTA.
Platformio.ini
upload_protocol = espota
upload_port = 10.0.0.208 ; IP-Address of the ESP32 device
upload_flags = --auth=xxx
adafruit/Adafruit ADS1X15 @ ^2.4.2
SPI
knolleary/PubSubClient@^2.8
When building I get the error message, that this board do not support OTA-upload:
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino, upload_protocol = espota)
-------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION:
PLATFORM: Espressif 32 (6.5.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
Error: This board doesn’t support upload_protocol = espota framework!
In the documentation there is the upload_protocol espota available for this board!
WEMOS D1 MINI ESP32 supports the following uploading protocols:
cmsis-dap
esp-bridge
esp-prog
espota
esptool
iot-bus-jtag
jlink
minimodule
olimex-arm-usb-ocd
olimex-arm-usb-ocd-h
olimex-arm-usb-tiny-h
olimex-jtag-tiny
tumpa
Default protocol is esptool
So, the question is why it is not working (for me) or what I have done wrong?
I don’t have a Wemos D1 mini ESP32, but I do have an esp32doit-devkit-v1. When I tested it with the configuration you provided (board = esp32dev
), OTA worked for me without any problems.
I see that you are using the Espressif32 platform version 6.5.0, which was just released yesterday. I suspect the update didn’t work properly so the platform is now broken.
Try uninstalling the platform. Also delete the corresponding directories (Windows: C:\Users\<username>\.platformio\platforms
and C:\Users\<username>\.platformio\platforms\packages
Reinstall the platform.
Build the project and wait until all components of the platform are installed. Then try an upload via OTA again.
By the way, there is a suitable setting for the Wemos D1 mini ESP32:
board = wemos_d1_mini32
Thank you for your answer. I’ve uninstalled the platform but there was no directory “packages” to delete. After reinstall, build and switch over to OTA it was the same error. When I reinstalled the platform I’ve selected the lastest version 6.4.0 but when building it was 6.5.0 - very strange.
Originaly the board setting was wemos_d1_mini32 but I wanted to test it with the more generic device to see if the error also exists.
That’s strange…
What’s the content of C:\Users\<username>\.platformio\
It should look like this:
Mode LastWriteTime Length Name
d----- 29.12.2023 05:40 .cache
d----- 13.12.2023 06:12 lib
d----- 17.12.2023 14:37 packages
d----- 24.12.2023 08:41 penv
d----- 12.12.2023 16:11 platforms
d----- 24.12.2023 08:41 python3
-a---- 27.12.2023 14:43 3848 appstate.json
-a---- 28.12.2023 20:42 5284 homestate.json
and it should contain a platforms
and packages
folder.
OK, I’ve missunderstod your previous post and was looking for the “packages” directory in Windows: C:\Users\<username>\.platformio\platforms
The .platformio directory looks like yours.
I’ve deleted the espressif directory in platforms and the framework-arduinoespressif32 directory in packages and reinstalled the platform but the error is still the same.
Have you tried setting up a brand new project and use the BasicOTA-Sketch?
My platformio.ini
works fine with espota:
upload_port = 192.168.2.123
After making a new project with the the code of the original project it is working like a charm. I don’t know what was broken in the original project. Thank you for your suggestion!
