Hi all,
I’m having some problems with updating my code via OTA. The way I have it set up is that I have a file titled ota_updates.cpp which contains a function called get_system_update(). Elsewhere in my code, I’m calling this get_system_update() function to download a firmware.bin file I upload to a Google Drive folder. It works well the first time but on the second attempt to retrieve the updated code, I receive a “Firmware upgrade fail” output to the console. I think this may be because I only have 1 app ota partition. I removed the second OTA partition because I only have 4MB of flash (I’m using a ESP-WROOM-32D) and each OTA partition should be as big as the app partition. However, my app is almost 1.5 MB in flash. My first question is do I need 2 OTA partitions and could this be what’s causing problems? Is there a way around this by changing the partitions.csv file or the code so that I only use 1 partition and have enough space for my app? If I must have 2 OTA partitions, I have an SD card that I can use. How can I load the app on the SD Card and configure partitions.csv so that it works with this card?
This is how my console output looks like:
.[0;32mI (15263) esp_https_ota: Starting OTA....[0m
.[0;32mI (15265) esp_https_ota: Writing to partition subtype 16 at offset 0x180000.[0m
.[0;31mE (15266) esp_https_ota: esp_ota_begin failed (ESP_ERR_OTA_PARTITION_CONFLICT).[0m
Http Event Disconnected
Firmware Upgrade Fail
Here’s how my ota_updates.cpp file looks:
#include "OTA_Updates.h"
#include "Arduino.h"
#include "HttpsOTAUpdate.h"
static const char *url = "MY_FIRMWARE.BIN_URL";
static const char *server_certificate = "-----BEGIN CERTIFICATE-----\n" \
"MIIDdTCCAl2gAwIBAgILBAAAAAABFUtaw5QwDQYJKoZIhvcNAQEFBQAwVzELMAkG\n" \
"A1UEBhMCQkUxGTAXBgNVBAoTEEdsb2JhbFNpZ24gbnYtc2ExEDAOBgNVBAsTB1Jv\n" \
"b3QgQ0ExGzAZBgNVBAMTEkdsb2JhbFNpZ24gUm9vdCBDQTAeFw05ODA5MDExMjAw\n" \
"MDBaFw0yODAxMjgxMjAwMDBaMFcxCzAJBgNVBAYTAkJFMRkwFwYDVQQKExBHbG9i\n" \
"YWxTaWduIG52LXNhMRAwDgYDVQQLEwdSb290IENBMRswGQYDVQQDExJHbG9iYWxT\n" \
"aWduIFJvb3QgQ0EwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQDaDuaZ\n" \
"jc6j40+Kfvvxi4Mla+pIH/EqsLmVEQS98GPR4mdmzxzdzxtIK+6NiY6arymAZavp\n" \
"xy0Sy6scTHAHoT0KMM0VjU/43dSMUBUc71DuxC73/OlS8pF94G3VNTCOXkNz8kHp\n" \
"1Wrjsok6Vjk4bwY8iGlbKk3Fp1S4bInMm/k8yuX9ifUSPJJ4ltbcdG6TRGHRjcdG\n" \
"snUOhugZitVtbNV4FpWi6cgKOOvyJBNPc1STE4U6G7weNLWLBYy5d4ux2x8gkasJ\n" \
"U26Qzns3dLlwR5EiUWMWea6xrkEmCMgZK9FGqkjWZCrXgzT/LCrBbBlDSgeF59N8\n" \
"9iFo7+ryUp9/k5DPAgMBAAGjQjBAMA4GA1UdDwEB/wQEAwIBBjAPBgNVHRMBAf8E\n" \
"BTADAQH/MB0GA1UdDgQWBBRge2YaRQ2XyolQL30EzTSo//z9SzANBgkqhkiG9w0B\n" \
"AQUFAAOCAQEA1nPnfE920I2/7LqivjTFKDK1fPxsnCwrvQmeU79rXqoRSLblCKOz\n" \
"yj1hTdNGCbM+w6DjY1Ub8rrvrTnhQ7k4o+YviiY776BQVvnGCv04zcQLcFGUl5gE\n" \
"38NflNUVyRRBnMRddWQVDf9VMOyGj/8N7yy5Y0b2qvzfvGn9LhJIZJrglfCm7ymP\n" \
"AbEVtQwdpf5pLGkkeB6zpxxxYu7KyJesF12KwvhHhm4qxFYxldBniYUr+WymXUad\n" \
"DKqC5JlR3XC321Y9YeRq4VzW9v493kHMB65jUr9TU/Qr6cf9tveCX4XSQRjbgbME\n" \
"HMUfpIBvFSDJ3gyICh3WZlXi/EjJKSZp4A==\n"\
"-----END CERTIFICATE-----";
HttpsOTAStatus_t otastatus;
void HttpEvent(HttpEvent_t *event)
switch(event->event_id) {
case HTTP_EVENT_ERROR:
Serial.println("Http Event Error");
break;
case HTTP_EVENT_ON_CONNECTED:
Serial.println("Http Event On Connected");
break;
case HTTP_EVENT_HEADER_SENT:
Serial.println("Http Event Header Sent");
break;
case HTTP_EVENT_ON_HEADER:
Serial.printf("Http Event On Header, key=%s, value=%s\n", event->header_key, event->header_value);
break;
case HTTP_EVENT_ON_DATA:
break;
case HTTP_EVENT_ON_FINISH:
Serial.println("Http Event On Finish");
break;
case HTTP_EVENT_DISCONNECTED:
Serial.println("Http Event Disconnected");
break;
void get_system_update()
Serial.println("gotchu better");
HttpsOTA.onHttpEvent(HttpEvent);
Serial.println("Starting OTA");
HttpsOTA.begin(url, server_certificate);
Serial.println("Please Wait it takes some time ...");
while (true)
otastatus = HttpsOTA.status();
if(otastatus == HTTPS_OTA_SUCCESS) {
Serial.println("Firmware written successfully. To reboot device, call API ESP.restart() or PUSH restart button on device");
delay(5000);
ESP.restart();
} else if(otastatus == HTTPS_OTA_FAIL) {
Serial.println("Firmware Upgrade Fail");
delay(1000);
Here’s how my partitions.csv file looks:
# ESP-IDF Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,16K,
otadata,data,ota,0xd000,8K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,0x170000,
ota_0,app,ota_0,0x180000,0x170000,
