Original dependencies
Hi community,
I have a legacy project that now is till need to update …
This is the .ini file
platform = espressif32@3.5.0
check_tool = cppcheck
check_flags = cppcheck: --enable=all --language=c++ --addon=misra.json
lib_ldf_mode = deep
	me-no-dev/AsyncTCP@^1.1.1
	me-no-dev/ESP Async WebServer@^1.2.3
	arduino-libraries/NTPClient@^3.1.0
	bblanchon/ArduinoJson@^6.19.2
	https://github.com/maxgerhardt/EthernetENC.git
	khoih-prog/Functional-Vlpp@~1.0.2
build_flags = -I include
board_build.partitions = esp32_app.csv
I discovered making full clean from vscode that the first two libraries are not longer availabe…
I would like to understand if still i can run the legacy code maybe just inserting the corrected libs but i don’t know how or where to take them
Updating to the lastest platorm or libs is giving me a lot of issues when i run the code…
Thanks
1.1.1 is still available per https://registry.platformio.org/libraries/me-no-dev/AsyncTCP/versions
1.2.3 is still available per https://registry.platformio.org/libraries/me-no-dev/ESPAsyncWebServer/versions
@maxgerhardt
Thanks for helping me…
But i think they have updated or did something different because when i compile i have issuess
What are the exact error messages?
@maxgerhardt
@maxgerhardt Hi Max… Did you have time to check how to restore the original repo with the old libs ? I put on github wgat was working. thanks
