OpenOCD JTAG ESP32-S2-Saola-1R embedding
Use the platformio.ini
[env:abiot-gateway-arduinoesp32]
platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip
board = esp32-s2-saola-1
    knolleary/PubSubClient@^2.8
    vshymanskyy/TinyGSM@^0.11.4
    plerup/EspSoftwareSerial@^6.13.2
    xreef/EByte LoRa E32 library@^1.5.2
    adafruit/RTClib@^1.14.1
    nickgammon/Regexp@^0.1.0
    bblanchon/ArduinoJson@^6.18.5
    arduino-libraries/Ethernet@^2.0.0
    openslab-osu/SSLClient@^1.6.11
    ayushsharma82/AsyncElegantOTA@^2.2.6
    ottowinter/ESPAsyncWebServer-esphome@^2.1.0
monitor_port = COM15
build_flags = -DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_DEBUG
upload_protocol = esp-prog
debug_tool = esp-prog
debug_speed = 500
and execute the project task “Build”, then “Advanced → Verbose Upload”. What does the latter one output?
Output is too large so I put it here https://pastebin.com/Cb1pfr78.
So upload is successful as well as programming. Also note that starting debug from CLI like: pio debug --interface=gdb -x .pioinit works, so, I feel like this is a bug in the extension.
Can you show that you execute this an then some, e.g., break loop and continue and backtrace to see debugging works during runtime? If that works, then it truely is in the extension.
