I’ve taken a look around the forums for this problem but just couldn’t get it sorted myself.
I’m very new to this kind of stuff, like started today kinda new, with the intent to do Manual Mesh Bed Leveling on my ender 3. I’ve downloaded Visual Studios Code, and installed the PlatformIO extension, as well as the Auto Build Marlin Extension.
I’ve currently got and SKR-Mini-v1.2 in my ender with Marlin 2.0bugfix already on it.
I’ve gotten all the files and everything from GitHub and followed along with some youtube videos, but where I get stuck where it seems everyone else I’ve seen flow right through is I get an [upload] error 1.
I’ll I’ve done up to this point is change the env to STM32F103RC_btt as per the recommendations. I hit build and everything come out fine but when I go to upload this is what comes up.
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103RC.html
PLATFORM: ST STM32 6.0.0 > STM32F103RC (48k RAM. 256k Flash)
HARDWARE: STM32F103RCT6 72MHz, 48KB RAM, 256KB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
- framework-arduinoststm32-maple 1.10000.190819 (1.0.0)
- tool-dfuutil 1.9.200310
- tool-openocd 2.1000.190707 (10.0)
- tool-stm32duino 1.0.2
Converting Marlin.ino
Looking for USBComposite_stm32f1 library in registry
Warning! Library `{'name': 'USBComposite_stm32f1', 'requirements': '==0.91'}` has not been found in PlatformIO Registry.
You can ignore this message, if `{'name': 'USBComposite_stm32f1', 'requirements': '==0.91'}` is a built-in library (included in framework, SDK). E.g., SPI, Wire, etc.
Found 38 compatible libraries
|-- <LiquidCrystal>
|-- <TMCStepper> 0.6.2
| |-- <SoftwareSerialM> 1.0.0
|-- <U8glib-HAL> 0.4.1
| |-- <Wire> 1.0
|-- <Adafruit MAX31865 library> 1.0.3
|-- <LiquidTWI2>
| |-- <Wire> 1.0
|-- <Arduino-L6470> 0.8.0
|-- <SailfishLCD>
|-- <SailfishRGB_LED>
| |-- <Wire> 1.0
|-- <SlowSoftI2CMaster>
|-- <STM32ADC> 1.0
|-- <USBComposite for STM32F1> 0.91
|-- <EEPROM>
|-- <Wire> 1.0
Checking size .pio\build\STM32F103RC_btt\firmware.elf
RAM: [==== ] 43.8% (used 21512 bytes from 49152 bytes)
Flash: [======== ] 85.0% (used 222716 bytes from 262144 bytes)
AVAILABLE: blackmagic, dfu, jlink, serial, stlink
Uploading .pio\build\STM32F103RC_btt\firmware.elf
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-11:28)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
======================================================================================== [FAILED] Took 9.09 seconds ========================================================================================
Environment Status Duration
mega2560 IGNORED
mega1280 IGNORED
rambo IGNORED
FYSETC_F6_13 IGNORED
FYSETC_F6_14 IGNORED
sanguino644p IGNORED
sanguino1284p IGNORED
melzi IGNORED
melzi_optiboot IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 IGNORED
LPC1769 IGNORED
STM32F103RC IGNORED
STM32F103RC_fysetc IGNORED
STM32F103RC_btt FAILED 00:00:09.095
STM32F103RC_btt_USB IGNORED
STM32F103RC_btt_512K IGNORED
STM32F103RC_btt_512K_USB IGNORED
STM32F103RE IGNORED
STM32F103RE_btt IGNORED
STM32F103RE_btt_USB IGNORED
STM32F4 IGNORED
STM32F7 IGNORED
ARMED IGNORED
STM32F103VE_GTM32 IGNORED
STM32F103VE_longer IGNORED
mks_robin_mini IGNORED
mks_robin_nano IGNORED
mks_robin IGNORED
mks_robin_pro IGNORED
mks_robin_lite IGNORED
mks_robin_lite3 IGNORED
jgaurora_a5s_a1 IGNORED
chitu_f103 IGNORED
STM32F401VE_STEVAL IGNORED
FLYF407ZG IGNORED
FYSETC_S6 IGNORED
STM32F407VE_black IGNORED
BIGTREE_SKR_PRO IGNORED
BIGTREE_GTR_V1_0 IGNORED
BIGTREE_BTT002 IGNORED
teensy31 IGNORED
teensy35 IGNORED
esp32 IGNORED
linux_native IGNORED
SAMD51_grandcentral_m4 IGNORED
rumba32_f446ve IGNORED
rumba32_mks IGNORED
include_tree IGNORED
================================================================================== 1 failed, 0 succeeded in 00:00:09.095 ==================================================================================
PS D:\3D printer Fixes\Marlin-2.0.x> echo "done" >C:\Users\nraud\AppData\Local\Temp\ipc
Hope someone can help out. Thanks in advance.
