Now its happening more often that everytime i try to upload code to my stm32, it fails with the following output.
$ pio run --target upload -v
Processing nucleo_f303k8 (platform: ststm32; board: nucleo_f303k8; framework: stm32cube; upload_protocol: stlink; platform_packages: platformio/tool-openocd@2.1100.211028; build_flags: -Wl,-u,_printf_float)CONFIGURATION: Redirecting...
PLATFORM: ST STM32 (19.3.0) > ST Nucleo F303K8
HARDWARE: STM32F303K8T6 72MHz, 12KB RAM, 64KB Flash
- framework-stm32cubef3 @ 1.11.5
- tool-dfuutil @ 1.11.0
- tool-dfuutil-arduino @ 1.11.0
- tool-ldscripts-ststm32 @ 0.2.0
- tool-openocd @ 2.1100.211028 (11.0)
- tool-stm32duino @ 1.0.1
- tool-stm32flash @ 0.7.0
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 28 compatible libraries
Scanning dependencies…
MethodWrapper([“checkprogsize”], [“.pio/build/nucleo_f303k8/firmware.elf”])
RAM: [= ] 6.9% (used 844 bytes from 12288 bytes)
Flash: [== ] 24.1% (used 15820 bytes from 65536 bytes)
.pio/build/nucleo_f303k8/firmware.elf :
section size addr
.isr_vector 392 134217728
.text 14728 134218120
.rodata 616 134232848
.ARM.extab 0 134233464
.ARM 0 134233464
.preinit_array 0 134233464
.init_array 4 134233464
.fini_array 4 134233468
.data 476 536870912
.ccmram 0 268435456
.bss 368 536871388
._user_heap_stack 1540 536871756
.ARM.attributes 42 0
.comment 126 0
.debug_frame 2216 0
Total 20512
([“upload”], [“.pio/build/nucleo_f303k8/firmware.elf”])
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
openocd -d2 -s /home/bob/.platformio/packages/tool-openocd@2.1100.211028/openocd/scripts -f board/st_nucleo_f3.cfg -c “program {.pio/build/nucleo_f303k8/firmware.elf} verify reset; shutdown;”
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-16-21:15)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
debug_level: 2Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : DEPRECATED target event trace-config; use TPIU events {pre,post}-{enable,disable}
srst_only separate srst_nogate srst_open_drain connect_deassert_srstInfo : clock speed 1000 kHz
Info : STLINK V2J46M31 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.233136
Error: init mode failed (unable to connect to the target)
in procedure ‘program’
** OpenOCD init failed **
shutdown command invoked*** [upload] Error 1
Am running this on an ubuntu 22.04, and i thought it was ModemManager that was grabing the SWD pin so that when OpenOCD wants to grab them and to reset, they are not available, i could be wrong. But this is how i did in on my box
sudo systemctl stop ModemManager brltty 2>/dev/null || true
and sometimes i just tried to disable it
sudo systemctl disable --now ModemManager
All these trials didnt seem to solve the issues for me. This is the current configurations in my platformio.ini file.
[env:nucleo_f303k8]
platform = ststm32
board = nucleo_f303k8
framework = stm32cube
platform_packages =
build_flags = -Wl,-u,_printf_float
I would also like to point out that i programmed arduino nanos, and i had no problem uploading the code to them. Only the STM32 is the one thats problematic. still on the same ubuntu platform.
